Alde on 2018 320s: not heating after de-winterizing
Jhealy34
Member Posts: 2
we used our alde last fall then winterized for winter. Last week we dewinterized and everything is working but the alde. I am trying to troubleshoot but no avail and looking for support.
Fuse not blown, hooked up to 30amp shoreline power, only using electric (not combo electric/gas), power at receptacle, hose levers all in proper position according to manual. I am not sure how to check glycol but I did not drain that last year.
What should I check next?
If it's not the hidden fuses on top of the Alde itself, it could be the thermal fuse on the circuit board. I keep a jumper 12 gauge wire and alligator clips to clip around that one in an emergency. Easy to make one at a hardware store2015 Max S Outback | 2010 Xterra -- Retired
2022 Ford F350 Tremor | 2022 Cirrus 6201 -
Is it plugged in? Look under the seat where the Alde is and make sure the black electrical cord is plugged into the 120 volt outlet.John and Henrietta, Late 2016 T@B S Max in Western New York1
@db_cooper , do you have any photos of how (and where on the board) you hook up the jumper cable?
Do you have a 320 (?model?) or a 400?
Do you have the digital display? Is that working?
Did you check the 2 Alde fuses located under the plastic lid AND the 12 v fuse in the fuse box? Assuming you have a 320, if it is plugged in under the bench, try it on LPG.
https://tab-rv.vanillacommunity.com/discussion/4197/found-a-fix-for-no-alde-heat-when-all-fuses-are-good
See Chan's photo below!2015 Max S Outback | 2010 Xterra -- Retired
2022 Ford F350 Tremor | 2022 Cirrus 6200 -
Thank you, @db_cooper . It really helps to have a photo, so I will copy it and hang on to it.
No! That's not the thermal fuse. That's a diode. (I have no idea what jumpering that diode would do!) @Bayliss.
@db_cooper you should probably edit your post so no one follows it by mistake!
The thermal fuse is here, in this photo.
Please check that referenced thread.
Chan - near Buffalo NY
A_Little_T@b'll_Do_Ya1 -
Thanks, I was looking for a stock photo and find from memory. Will delete.2015 Max S Outback | 2010 Xterra -- Retired
Thanks @db_cooper, hope I didn't sound like I was jumping down your throat. I was rushing to prevent someone's catastrophic Alde explosion!
No worries! I was trying to be helpful, but was in a hurry, need to be more careful. Glad you spotted it!2015 Max S Outback | 2010 Xterra -- Retired
If you jumper the thermal fuse F2, please consider that a very short term attempt only to find out whether the fuse is bad, not a permanent fix. That fuse is the last line of defense against the Alde incinerating itself.John and Henrietta, Late 2016 T@B S Max in Western New York0
I would open up the area that holds the Alde and see if you have glycol in the tank or to see if you have had a crack in the tank over the winter. The glycol should be according to what I have read here, between the minimum & maximum line.2018 Tab 400
2016 Nissan Frontier SV 4x4 Crew Cab0 -
Thanks everyone, we found the issue from your comments. Have heat and ready to roll!!!0
Ok, I'll bite! What was the issue?
@Jhealy34– yes please let us know your solution— it helps others in the future if they have the same issues!2018 Tab 400
2016 Nissan Frontier SV 4x4 Crew Cab1 -
Yeah, what they said!
Probably was a fuse.
We may never know! 🙄-Brian in Chester, Virginia
If the glycol reservoir was dry, there would be no heat.
Voice of experience.....Verna, Columbus, IN
Towed by a white 2019 Ford F-150 4x4 Supercab, 3.5L V6 Ecoboost “The Truck”0
- 427 Service/Maintenance & Recall Notices
