Alde on 2018 320s: not heating after de-winterizing
we used our alde last fall then winterized for winter. Last week we dewinterized and everything is working but the alde. I am trying to troubleshoot but no avail and looking for support.
Fuse not blown, hooked up to 30amp shoreline power, only using electric (not combo electric/gas), power at receptacle, hose levers all in proper position according to manual. I am not sure how to check glycol but I did not drain that last year.
What should I check next?
  • db_cooper
    db_cooper Member Posts: 749
    If it's not the hidden fuses on top of the Alde itself, it could be the thermal fuse on the circuit board.  I keep a jumper 12 gauge wire and alligator clips to clip around that one in an emergency.  Easy to make one at a hardware store
  • Photomom
    Photomom Member Posts: 2,217
    Is it plugged in? Look under the seat where the Alde is and make sure the black electrical cord is plugged into the 120 volt outlet.
  • Bayliss
    Bayliss Member Posts: 1,534
    @db_cooper , do you have any photos of how (and where on the board) you hook up the jumper cable?
    Do you have a 320  (?model?) or a 400?
    Do you have the digital display?  Is that working?
    Did you check the 2 Alde fuses located under the plastic lid AND the 12 v fuse in the fuse box?  Assuming you have a 320, if it is plugged in under the bench, try it on LPG.
  • db_cooper
    edited March 2019
  • Bayliss
    Thank you, @db_cooper .   It really helps to have a photo, so I will copy it and hang on to it.
  • ChanW
    ChanW Member Posts: 3,171
    edited March 2019
    No! That's not the thermal fuse. That's a diode. (I have no idea what jumpering that diode would do!) @Bayliss.
    @db_cooper you should probably edit your post so no one follows it by mistake!  ;)
    The thermal fuse is here, in this photo.
    Please check that referenced thread.
    Chan - near Buffalo NY
    2014 S Maxx (ie: "320")
  • db_cooper
    Thanks, I was looking for a stock photo and find from memory. Will delete.
  • ChanW
    Thanks @db_cooper, hope I didn't sound like I was jumping down your throat. I was rushing to prevent someone's catastrophic Alde explosion!  =)
  • db_cooper
    No worries! I was trying to be helpful, but was in a hurry, need to be more careful.  Glad you spotted it!
  • Photomom
    edited March 2019
    If you jumper the thermal fuse F2, please consider that a very short term attempt only to find out whether the fuse is bad, not a permanent fix. That fuse is the last line of defense against the Alde incinerating itself.
  • lkc001
    lkc001 Member Posts: 881
    I would open up the area that holds the Alde and see if you have glycol in the tank or to see if you have had a crack in the tank over the winter.  The glycol should be according to what I have read here, between the minimum & maximum line.
    2018 Tab 400
  • Jhealy34
    Jhealy34 Member Posts: 2
    Thanks everyone, we found the issue from your comments. Have heat and ready to roll!!!
  • ChanW
    Ok, I'll bite!  What was the issue?
  • lkc001
    @Jhealy34– yes please let us know your solution— it helps others in the future if they have the same issues!
    2018 Tab 400
    Yeah, what they said!
  • lkc001
    2018 Tab 400
  • BrianZ
    BrianZ Member Posts: 1,770
    Probably was a fuse.
    We may never know!  🙄
  • Verna
    Verna Member Posts: 6,876
    If the glycol reservoir was dry, there would be no heat.
    Voice of experience.....
