FUSES?
lkc001
Member Posts: 877
I know that some people used to call Elsie at nucamp for fuses. Where do you get your fuses now? Are all the fuses used normal fuses you would find through autoparts store or Amazon?
2018 Tab 400
Yes, you can get the fuses just about anywhere. When we were at uCamp last year, the Alde rep handed out Alde fuses!Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
I got these 3 items, which I think covers everything you might need..
GlowGeek 100pcs Assorted Auto Car... https://www.amazon.com/dp/B06XY2V532
BCP pack of 10 pcs F3.15AL... https://www.amazon.com/dp/B01AN353VO
UCTRONICS 15 Values 150pcs... https://www.amazon.com/dp/B01M63P756
And look for Fuses For Newbies and you can buy pretty much just what you need, without having to buy the big family pack assortments. The file also has nice pictures and descriptions of where the fuses lie in wait.
Towed by 2014 Touareg TDi -
While the 400 is configured differently than the 320, the fuses should largely be the same and this PDF has an index of parts and where to get them.F150 Pulling 2019 T@B400 BDL
In the past there has been some debate about whether the Alde glass fuses should be fast blow or slow blow. I'm not sure we ever got a definitive resolution.
Fast blow per Fuses for Newbies
Understood, but the debate arose after the creation of Fuses for Nubies. The slow-blows have been suggested (apparently even by Alde) as an alternative for those having repeated issues with blown fuses. As I note in the above-mentioned discussion, mine came with fast-blows installed and a pack of slow-blows attached as spares. Curious.
@ScottG, this does not address fast or slow but adds to the whole Alde issue.
https://tab-rv.vanillacommunity.com/discussion/7953/alde-control-panel-dark-does-not-work-alde-blows-3-15-amp-fuses-why-run-a-new-ground-wire
Here is another one - mentions using a 5 amp fuse, but the ground wire seems to be the cure instead of a fast vs slow blow.
https://tab-rv.vanillacommunity.com/discussion/5813/running-a-ground-from-the-alde-to-the-battery
Yep, the 5A fuse swap out was also mentioned by Alde somewhere in that discussion I linked to.It's interesting that some Alde's have this problem and others don't. I have the original fast-blow fuses still in my unit (knock on wood...) while the factory provided slow blow spares and the fast blow spares I purchased separately stand at the ready.2015 T@B Max S (320)
I think the point made by Mike in one of those links - to avoid surges by turning everything off before disconnecting and reconnecting- goes a long way to prevent the fuse blowing. We tested that theory last summer and it proved true.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
Here's a link to the thermal fuse for the Alde circuit board
https://www.digikey.com/products/en?keywords=317-1127-ND
2015 Max S Outback | 2010 Xterra -- Retired
2022 Ford F350 Tremor | 2022 Cirrus 620
- 920 Introductions
- 74 Teardrop Groups & Links
- 915 Tips & Tricks
