Does anyone else who has a T@B 400 Boondock have their diamond plate tub mounted about 4 inches from the trailer’s wall? The tub has a rubber seal that follows the curve of the wall, but it’s mounted so far from the wall that it serves no purpose. I don’t know that the tub could have been mounted further back due to the spare tire drop lug, but it seems a bit misplaced, or at least a design opportunity.. Also, the LP tank to regulator hose is pulled so tight I’m worried the edge of the diamond plate might be sawing through it as the trailer jostles. Anyway, just wondering if my 400 Boondock might be needing some adjustment.
Alan & Natalie McKinney, TXnüCamp: 2019 T@B 400 Boondock Lite
0 ·
New surprises everyday
See beautiful world
TV 2005 jeep TJ unlimited
Alaskan Malamuthe on board!
Not sure how they could have mounted it that far away as the tubs have predrilled holes. Here are two pictures from our 400BDL showing the tub should be mounted just touching the front of the T@B. We have plenty of distance from the top of the tub for the propane hose but wish it was about 2" longer to take away some of the strain on the connection.
https://www.youtube.com/watch?v=E7ad-8qXKkA
The above is another video tour and at the end you see the tub in front of the spare tire crank also. The one that goes over the crank looks like it has been cut out with a notch?
See beautiful world
I wonder if that isn't the issue. I re-watched the Travels with Delaney video, and you can see inside the tub when he opens the lid, and it clearly goes over the spare tire cross brace - and appears to be notched to accomplish this. Your tub clearly isn't the same design - so the only question is whether the design has been changed, or did you get the wrong part?
But the 320's battery lives in the tongue box...so more evidence of the wrong part?
Question for anyone... if I were to get them to order and drop ship the right one, how hard is the install? Anyone done it? Is it just bolted to the frame? No rivets or welding? Thx!
I really want to replace the composite box on our T@B with an aluminum box with more room (I want to get the H2O hose, sewer hose, small generator, if I can, and a small tool box in it), but haven't found anything I really like. What are others doing?
I know I'll need to drill drain and vent holes and watch tongue weight, but someone out there has already done this, I'm sure.
https://tab-rv.vanillacommunity.com/search?Search=New+tongue+box
