Bike rack
Tabaz
saw this ad in trailer life magazine. Google "limppert bike rack."
Lippert components "jack-it"2016 Outback 320
This gizmo: http://www.lci1.com/jack-it2015 T@B Max S (White/Silver) -> 2014 Ford Escape 2.0L (turbo, AWD, factory tow)3
Do you think it would fit a 2016 Outback. It looks like it goes 'over' the jack. Has anyone used this yet?Sun Valley Idaho living, 2 restaurants, 2 labs, 1 helluva wife! 2016 T@B Max-S Outback towed by. 2007 Toyota FJ Crusier0
I just installed the jack-it on my 2016 Outback.
To install, remove the tongue jack, set the rack base in place, insert the jack through the base, and secure with the included long bolts. The rack does not interfere with the tongue jack crank.
I only have 1 bike, but this can easily hold 2 bikes. The "Y" portion of the rack angles back about 4 inches from the tongue. The propane box should still be accessible when a bike is on the trailer side of the "Y" arms.
2016 Outback MAX S, 2014 Ford F-150 FX40 -
Just to be clear, the Jack is on the T@B - Correct?0
Yes, it's on the T@B. Here's a pic of the base.
2016 Outback MAX S, 2014 Ford F-150 FX42 -
This unit is much different than the one on their website. No drilling into the frame with this one. Thanks for posting the pictures.2016 Outback 320
I like the JACK It bike rack. I was thinking of using a Curtis double hitch which has a section to put a 2 inch ball on the bottom to tow the trailer and above the hitch ball is another 2 " hitch to put a bike rack in. Has anyone out there used one of these 2 hitch set-ups to carry bikes and tow there T@B at the same time ?
Thanks - Dockguy
I have had good results with a hitch mounted version of the bike rack portion called a "SportWing" bile rack.
The Jack-it seems like a good solution for trailer mounting the same rack.
A local RV dealer has the Jack-it on display and in stock. If your curious you might
want to look local.
I opted for Yakima rack that mounted to my TV. I wanted something that wasn't specific to when I camped. I use mine for every day use and when I hook up my tab. Think about you use case before buying.
2017 T@B 320-S, Sofitel (M@bel)
Mabel is my great grandmother that I never knew. She took her 3 sons (ages 8-2) on an epic adventure from Alabama to Florida in the 1930's in the back of a pick up truck. I named my female English springer spaniel after my mother. Might as well go for broke with the brownie points in Heaven!
TV: 2018 Ford F-150 Lariat Supercrew
David & Jill, Houston, TX0 -
It looks like the Sport Wing goes into the hitch perpendicularly while the Jack-it requires a vertical bike rack. It would be nice to have the bike rack work for both the car or trailer so you could use it either way depending on whether you are camping or just using the car. Is there an adaptor that would make this possible?0
texasaubiefan I've been thinking of the same thing - just using my current bike rack on the TV. Have you experience any issues?2017 CS-S Max (Silver & Yellow), TV 2019 Ram 1500
Camping under the Big Sky0 -
I tried the Jack-it and returned it. Didn't like how it has to be installed on top of bolts. There are bolts on the A frame that were in the way.
2017 T@b 320 S
2017 Kia Sorento SXL AWD
I use this item, MaxxHaul 70070 Dual Hitch Extension - 4000 lbs. GTW Capacity, , with my current bike rack when I pull my T@B. When not camping the rack can be used in the standard setup in my hitch. I have not had any issues either way.Linda & Dan
Cleveland, Ohio
2018 Ford F150 XLT pulling a 2020 T@B 400
LIFE IS GOOD!2 -
Looking for a bike rack solution in 2019. Would love to hear from you all about good solid choices. I have to bikes to carry.
many thanks!
Greg0 -
If you haven’t done so already, search on “bike rack” in the search field in the upper right. As you can imagine, there are many threads with photos. There are different types to accommodate your tow vehicle’s rear hatch, trunk, tailgate etc.John, Judi, Guinness & OD in PDX
o yeh, I see. thanks. that pulled up a lot more. I thought I had done that, but I actually did a google search instead.jgram2 said:If you haven’t done so already, search on “bike rack” in the search field in the upper right. As you can imagine, there are many threads with photos.0 -
I searched and found several from March and April of this year. Maybe try again?John, Judi, Guinness & OD in PDX
We understand... Searching here can be difficult. Lots of info here for sure. We all want to help. Many questions have been answered before, hence the earlier advice. Older dated posts do not mean outdated ideas...
Here is what I went with after watching a vid from Mandy.
https://mandyleaphoto.com/2017/11/26/a-bike-rack-solution/
Terry & Jody... 2025 Honda Ridgeline RTL
2016 NuCamp 320 T@B Max S
T@bbey Road
Appleton, WI1 -
Thank you! I did see this but It makes me too nervous to have the rack waggling around. I want to find something where the bikes are solidly fixed in place. I may decide it's better to use a roof rack on our truck instead.TerryV6 said:We understand... Searching here can be difficult. Lots of info here for sure. We all want to help. Many questions have been answered before, hence the earlier advice. Older dated posts do not mean outdated ideas...
https://mandyleaphoto.com/2017/11/26/a-bike-rack-solution/1 -
@gkillmaster, I was going to ask if you were looking to put the bikes on your T@B or your tow vehicle, but it sounds like you are open to either.It also sounds like you have a truck. Does it have a full (6') bed? I carry two bikes clamped upright in the bed of my track, under a cap. It doesn't get much more protected than that, and--since we ride mostly off-road--the bikes are packed and ready for transport from the campground to the trailhead.You might find this poll/discussion of interest.2015 T@B Max S (320)
Thank you ScottG! most helpful!ScottG said:@gkillmaster, I was going to ask if you were looking to put the bikes on your T@B or your tow vehicle, but it sounds like you are open to either.It also sounds like you have a truck. Does it have a full (6') bed? I carry two bikes clamped upright in the bed of my track, under a cap. It doesn't get much more protected than that, and--since we ride mostly off-road--the bikes are packed and ready for transport from the campground to the trailhead.You might find this poll/discussion of interest.1 -
@gkillmaster, if it's an option for you, I use a couple of these clamps (there are multiple brands) mounted to a board that secures temporarily in the bed of the truck when needed. They are very secure and can be adapted to a homemade roof rack as well.
Thanks again ScottG. Will look into this option when I can.0
I started another discussion a few days back asking T@bber’s thoughts about the Seasucker racks (link below). I’ve now received mine, and will be “cautiously” testing it for the next few months. I certainly understand others hesitations for such a system, as I am still working through my own. For me, I think I like the “roof of TV” options vs “on the trailer”, as it gives us more flexibility for carrying from camp to trailheads and/or at other times while not camping. But others may not have that option, or need the space for other storage. I actually did buy the Jack-it too, but it’s still in the box. Holding it as another option, should the Seasucker choice become problematic.
https://tab-rv.vanillacommunity.com/discussion/8708/seasucker-bike-rack-any-brave-souls-yet#latest
Alan & Natalie McKinney, TX
nüCamp: 2019 T@B 400 Boondock Lite
Dream big... work hard... never give up.0
- 144 Events & News
- 76 Teardrop Groups & Links
- 921 Tips & Tricks
