Hi all,
After several years of happy camping with rabbit ears and mostly without my working husband, who was working, we now require a better antenna. (I always figured if the tv did not get any stations, read a book). However after being at a somewhat remote campground during the final four, and my husband's retirement, we require a better antenna. I've found one that fits the bill but am trying to sort through the hook up prior to purchase.
All of these antenna are amplified and require low voltage electricity. The antennas in my home that are amplified either plug in to the usb port on the tv or an adapter and into the wall. The connections on the back of the stock interior tv in my 2016 CSS are a DC12, an HDMI and a standard coaxial connection. There is an empty usb port, which I'm thinking is for the amplified antenna.
Has anyone figured out an amplified signal outside antenna hookup? Maybe just an extension cord and plug it in outside?
Thanks for your help, safe travels and happy trails.
Denise
Denise, Rea and Ruby
2016 CS S, 2008 Toyota Tacoma
Somerset, VA
0 ·
Somerset, VA
When we got the amplified antenna below, it came with the pictured power injector, which is a short coax cable with a small box that accepts a power input from a provided USB cable which plugs into to back of our TV. We just plugged the coax cable that comes in behind the tv from the outside coax port, into the power injector cable which then goes into the TV. Power is injected into the antenna which is plugged into the outside port & raised on a painter pole mast attached to a front handle.
I think this is typical for any of the powered antennas.
Or does your T@B not have the outside coax port?
[New Concept] 1byone Amplified Outdoor Antenna with Omni-Directional 360 Degree Reception, 60 Miles Indoor/Attic/Outdoor TV Antenna for FM/VHF/UHF, Tools-Free Installation, Anti-UV Coating-White https://www.amazon.com/dp/B01N06CBFO
2013 Tundra TRD 5.7L
Massachusetts
Denise
Somerset, VA
Adventures: 55 Nights: 376 Towing Miles 46,920
table mod
(Alde: 3020; Refrig: Isotherm Cruise 65 Eleg; Battery: BB 100Ah LiFePo4; Solar: Renogy 100Ah Suitcase; Victron BMV-712; Pwr Cntr: PD-4135KW2B; EMS: PI-HW30C)
EDIT: Thinking through this further, you might have a problem if you're getting your 12V DC power from a USB port. USB is notoriously underpowered--usually limited to about 2.1A or lower. If you find you are getting lousy reception from your antenna and you're using USB, try a cigarette lighter socket. You'll get more amps. At least 5 and possibly as many as 15, depending on how it's fused.
Great info and graphics, thanks all.
Denise
Somerset, VA
If you live in a metro area try scanning the channels without the amplifier portion in the behind the TV.
I found at home I get 6 more stations without than with. Same for our trip to Winton woods in cincinati
https://kingconnect.com/support/product-support/initial-setup-king-jack-antennas/
Springfield, MO
Springfield, MO
