Does anyone know what the Atwood model number is for the yoke style coupler depicted in this photo?  It is mounted on my 2019 320S Boondock Lite.  I downloaded the Atwood installation documentation for their coupler's, but I cannot determine from their drawings which model I have.  I was trying to figure it out so I could order the Proven Industries (PI) coupler lock.  The PI Model #2178-A shows this coupler as one of the two that work with that particular lock, so that is what I ordered.  Still, it would be nice to confirm the Atwood coupler model number.  Thanks!  (Greg)
                2019 T@B 320 S Boondock Lite; 2025 Toyota Tundra CrewMax 4x4
0 ·
Atwood has several Yoke Coupler part numbers. My money is on the 80082 part number.
Because the photos I have of my coupler are insufficient to resolve which model I have, next time I go to where my camper is stored, I plan to take a closer look at the coupler to determine (1) how it is attached to the A-Frame (it does appear to be welded), (2) measure the width of the channel, and (3) use a flashlight to look down into the channel housing to see if the part number is stamped on the top of the channel. Although probably not applicable to exactly what is on my camper, if anyone is curious, I found this video of #80051 on eTrailer.com:
https://www.etrailer.com/comparison.aspx?pc=AT80082&pc2=AT80051
SIDE NOTE: Just an FYI...............I previously purchased a Fastway Fortress coupler lock (Model #86-00-5015 or #DT25013) and discovered that although designed for the Atwood Yoke Style coupler, it does not work with the straight channel version. This is because the detent ball head on the Fastway lock is not tall enough to engage with the Atwood coupler lock. If anyone happens to be using the Fastway lock with the straight channel coupler, check to see if the detent ball head on the Fastway lock actually locks in place when the Atwood coupler latch is in the closed/locked position. If not, when you release your hold on the lock bar/body of the Fastway lock (i.e., when the shackle is not yet attached) it will fall to the ground. Also, when the shackle is locked in place, even though it may appear secure, it is actually very easy to dislodge the shackle by either prying it off the coupler, or striking the shackle with a hammer. That is why I have ordered the Proven Industries lock, which I know will work and provide much better security.
I hope the pictures answer the real question. Note the chains and hooks are locked in the box.
I've been using two (cheap) Master Locks (ball and coupler lock pin) as well as TriMax Wheel Lock but am starting to think it is time for a real tongue lock.
Did either of you consider the Fort Knox or 'The Vault' by Megahitchlock before selecting the Proven brand/model ?
Fort Knox, $198 if you buy their puck lock $149 if you use your own, is lighter steel & hinged, has a punk lock, and covers the coupler lever/lock pin area.
"The Vault", $199, does not use a puck lock or cover the coupler lever/lock pin area.
Both have can't be broken destruction videos like the Proven Product.
Although I could not clearly read the rated weight capacity stamped on my coupler, the document I found on the Internet indicates that the capacity is 6,000 lbs., which is consistent with what I believe the stamp on mine reads. Significantly greater than what I would expect for a T@B 320S.
Thanks again for everyone's input. (Greg)
Arrived today.
Trying to figure out security options for our impending T@b400, but the Brahma wheel lock just seems like it's so cumbersome to install that I can't imagine my wife ever using it.
Has anyone ever used Proven Industries' wheel lock on a T@b? They only list one tire size on their website, which seems odd.
2024 T@g 5-wide Black Canyon
The PI wheel lock is only for trailers without brakes and with leaf spring suspension, and not Dexter Torflex axles like T@B.
https://www.provenlocks.com/collections/wheel-locks/products/wheel-lock-model-wl-100
Read the Attention: message
I have both the PI and Brahma locks. Expensive but they give peace of mind- (or did). LOL
I was thinking of PI's WB-300 Wheel Boot (sorry, not 'lock'), which is listed as only compatible with size 205/75/15 tires. Still doesn't cover the lugs, so at $299, starting to get real steep.
Seems like the Brahma is the only reasonable option for (truly) protecting the trailer from being stolen, while the PI-278A coupler lock would at least slow down casual thieves from a quick getaway.
While the Brahma is indeed heavy and a bit awkward to install, if you have decent physical strength and can sit on ground (and get up again) it really isn't bad once you figure out the puzzle so to speak. I seriously doubt a thief will make off with a trailer or vehicle with that wheel lock installed, not without power cut off Saws or a torch anyway.
https://tab-rv.vanillacommunity.com/discussion/comment/83154#Comment_83154
https://www.youtube.com/watch?v=2O5YQUa4WxM&feature=emb_err_woyt
Perhaps the Brahma is truly the better money to spend. I'm a bit put off by the size and weight to be carried around, but I don't think I can find fault in how secure it would be.
