I did a quick search of the site for condensation and didn't see this directly answered, but alluded to:
Does the A/C in the Tab 320s with the AC up high (the window unit) .. does it have a condensation drain tube? I was poking in the cabinets looking for a hole to run a wire through and had pulled the A/C frame off to kind of get a nose in.. and it looks like it's just sitting there in the cabinet and I can't see if there's drain tubing.. It strikes me that in humid locations .. if that is not drained properly it could cause a big mess..
I've seen a few posts alluding to how the new location of A/C addresses some issues .. but didn't directly see it said (very likely missed it or didn't search the right terms)
Here it is. Located at the front, right area of the A/C cabinet. The round cut-out is the access hole behind the mirror in the bathroom. You should be able to see the drain tube (its clear) in the pedestal area with the seat cushion removed.
a better photo.
2019 T@B 320 S Boondock Edge named "Binky" | TV: 2016 Chevy Colorado Z71 with full tow package and a Leer Cap for lots of storage
The photos are form a previous post on how to remove the A/C unit:
https://tab-rv.vanillacommunity.com/discussion/2709/how-to-remove-the-air-conditioner
Glad they could help.
Knowing the position of the drain and such .. indeed it suggests to me that a teensy bit nose down would be good when running the AC
As for drafts/external.. I was thinking about getting or creating a cover to put on it when traveling.. I've heard several folks mention that it can lead to dust ingress.
https://www.enhancedperformancesystems.com/product-page/t-b-320-a-c-vent-door
For now, I'm likely going to mount the antenna on a pole I can strap to the entry handle or to the metal platform on the front.. set it up and break it down as I go till I really figure it out, or give up and pay my RV dealer to install it.
I'm generally pretty handy, but I tend to avoid putting holes in walls/roofs.. if I can find an egress that is already present.. ok fine.
