Before we even get started, I know some travel with their propane ON, so this thread is not intended for you all. SORRY! I'm having a discussion on other RV FB sites about the importance of turning off the Propane while traveling. I even had a guy say that NEVER will propane explode. OMG. So, people who turn theirs OFF, please feel free to give me your more potent, intelligent,thoughtful descriptions, opinions, examples of the NEED to turn off propane while traveling.
0 ·
Most RV refrigerators can keep food/beverages cold during several hours of travel without a power source. It is recommended that propane systems be turned off while driving. https://www.amerigas.com/amerigas-blog/2011/july/rv-propane-safety
I do find the nature of this original question interesting. Sort of like saying "I want to have a debate on this subject so that I know more about it. Please don't bother responding if you don't agree with me."
Some tunnels actually have a slight curve to them so that the high point is in the middle and the low points are at the ends (mountain tunnels) in part to keep heavier than air gases from accumulating.
Mostly I believe the 3 ways are meant to be pre-chilled by 110v or propane before you set out.. make sure you have a good solid, cold thermal mass in there (throw in frozen water jug if room) and then run on 12v while towing.. the TV should keep the battery topped off enough... switch to AC or Propane once you're stopped for the night/ at your destination
2019 T@B 320 S Boondock Edge named "Binky" | TV: 2016 Chevy Colorado Z71 with full tow package and a Leer Cap for lots of storage
Many Youtube RVers travel with propane on, Long honeymoon and Travel with delaney come to mind, that is the reason he got rid of their prior trailer, propane fridge wouldn't stay lit while traveling.
Again there is no right or wrong answer. I would follow the posted laws and common sense.
Like klenger I have my Tow Vehicle wired to provide 12 volts to the trailer and if my fridge didn't run on 12 volts DC I would probably buy an inverter to run it while traveling. But that is just me.
On longer road trips I run fridge 2 hours on 12v, then 2 hours off.
This keeps trailer battery charged and food cold.
For one thing there shouldn't be an open flame anywhere near your vehicle while fueling. Example, a pilot light.
Another issue is for those who've installed custom tubs. Ventilation should include bottom of the tub so any propane leak would flow out and disperse.
The closest I can tell, "propane off while traveling" is absolutely the law in some states, but it seems to vary by state.. Just about any tunnel that allows vehicles with propane tanks (some entirely prohibit travel in tunnels with any propane .. even off) requires they be off, limits the number of tanks/total propane... the most comprehensive state by state I could find is here:
https://www.goodsam.com/article/default.aspx?articleID=2377513
Note they do not quote sources, but at least here you can CTRL+F for propane and see that a few states have blanket prohibition on open propane.. Likely you'd need to dig into the state statutes to find it since they don't reference.
Honestly folks are going to do what they find works for them regardless of laws or anything written here.
If you do decide to run with the propane on you must be sure to turn your pilot off if you enter a gas station. Pumping gas with an open flame is unsafe and illegal...you will need to pull over and refire after you leave the service station. It's also a good idea to learn the laws where you are going and abide..and finally, your propane sensor will trip if you have a low battery or if you are unplugged from the 7 pin...be aware.
Harpers Ferry, WV
These threads are always entertaining. Sorry the app didn't have the info you were seeking.
