Newbie owner of a 2008 t@b. I see that lots of folks install roof vent covers. Scratching my head over how a flat bottomed cover (which they all seem to be) works on the extreme curve on a teardrop trailer. Also, how to tackle the installation without putting weight on the roof?
0 ·
I used an extension ladder leaned over the side/corner with lots of padding under it to protect the trim, then layed on the ladder. Also had plywood & padding on the ladder to lay on. This gave me enough reach to work on one side at a time. I also used a 6-ft stepladder next to the side of the trailer to climb up onto the extension ladder. I did have to be careful not to climb out too far over the roof, and kept enough ladder extended on the ground to weight down that side of the teeter-totter. Or you could use some tent pegs to stake it into the ground.
2019 T@B 320 S Boondock Edge named "Binky" | TV: 2016 Chevy Colorado Z71 with full tow package and a Leer Cap for lots of storage
I was previously going to install the Camco Aero-Flo on my 2019 320S Boondock Lite, but it is not compatible with the plastic attachment brackets on the newer stock Dometic vent lid (see this thread: https://tab-rv.vanillacommunity.com/discussion/8414/what-is-the-purpose-of-the-plastic-brackets-on-the-outer-edge-of-the-rooftop-vent-base#latest .)
I can easily install the Dometic Fan-Tastic Ultra Breeze cover, which uses those plastic attachment tabs, but I am hesitant since it has a higher profile. [UPDATE: I did purchase the Ultra Breeze U1400 cover and am very happy with it.]
Thanks!
By the way, I can't tell if you have it or not, but you can separately purchase a bug screen that sits inside the large plastic grate. The rate keeps out birds, etc., but the finer mesh bug screen will keep out small insects and most other debris.
https://www.amazon.com/Fan-Tastic-U1550BL-Ultra-Breeze-Screen/dp/B009CYJQC8/ref=pd_bxgy_263_img_3/132-4692977-5158240?_encoding=UTF8&pd_rd_i=B009CYJQC8&pd_rd_r=0f12f785-8c89-11e9-9752-2bd817123352&pd_rd_w=MZ7cX&pd_rd_wg=oBJ0q&pf_rd_p=a2006322-0bc0-4db9-a08e-d168c18ce6f0&pf_rd_r=3B7MQ7N4RPVYX8SPPQRX&psc=1&refRID=3B7MQ7N4RPVYX8SPPQRX
As to appearance - it looks a bit bulky at first, but we've gotten used to it:
pics aren't the best as I was more taking a pic to show the "side tent" but as oyu can see, it kind of ends up blending into the background (why I went with smoke color)
2022 Ford F350 Tremor | 2022 Cirrus 620
John & Lori in Northern VA
Former owner of 2015 T@B CS Max "Uteki" aka "H@wk T@B"
2012 Toyota Tacoma Double Cab 4x4 Off-Road "Zame"
