The city water and water tank are not connected. You do not need to turn on your inside water pump if connected to city water. It only operates the fresh water tank. You can turn on the city water and leave it on.
If you haven't already, you probably should get a pressure regulator that screws onto the end of your hose, then connects to the T@B. Many campgrounds have pressure that is too high for the T@B.
The regulator looks like this and can be bought in the RV section at Wal-Mart, or any RV supply store.
BTW, the only bad question is the one not asked.
City water is "on demand", meaning, once you turn it on outside, it will be immediately available when you open a faucet inside.
Pressure regulator is a must. A big rig owner parked next to me in Moab late year recommended putting the regulator between the hookup at the campground and your hose. He said leaving the hose n the sun will build up some pressure and putting the regulator first could help offset that.
. Still I recommend that you check your water connections in the T@B when the water is turned on outside. The older T@B trailers like ours use mostly hoses which can easily leak at the connections if you have too much water pressure even with a pressure regulator. I am not sure how solid the pipe/hose connections are in the newer trailers but I have seen leaks in a newer T@B's as well as older ones if the pressure was too high. We usually turn off the water at the source when we do not use it for a long period during the day just to be on the safe side.
Non-T@B experience. New old house with full basement, clothes washer included with non-braided hoses. It was on my list to change those hoses out! Several months later, woke up one morning to a strange sound from the basement. Split hot water washing machine hose, pointing straight up at the basement ceiling. Not just a flooded basement, but the water hit the ceiling and sprayed down like a sprinkler system. *sigh* Lesson learned. Always use braided water hoses for the washing machine.Michigan_Mike said:....
Water damage can be serious and this is a great discussion as I do know that from time to time there are issues that have been discovered in the trailers by owners whether it be from Mother Nature or via a loose or defective fitting. Water is the most invasive and erosional element on the planet and will find it's way into any opening, whether large or small. I know that I do my best to shut off water in my home (flipping the main breaker on my pump) and also shut off my outside faucets on the house. And with horror stories of broken/frozen pipes, cracked fittings via frost/winter temperatures, I have installed the braided hoses on my washer in the laundry room. Unfortunately, many of these tasks and upgrades have come via the agony and misfortune of friends, neighbors and family members and personal experience.
Thanks to all who have contributed as we can all learn and benefit from these types of discussions.
Well done!
RZRBUG said:Jenn, if the heat from the sun can build up pressure in the hose (and it can to some extent), doesn't it make sense to put the regulator next to the T@B? I mean, if you put the regulator at the campground connection and the sun builds up pressure past the regulator, that pressure is then unregulated at the trailer connection.
That is what I wondered, too. There seems to be 2 very different schools if thought, but it does make sense to me that replacing a hose is better than dealing with damage from the pent up pressure.
But, I will say, no issues from hose laying in full sun in July in Moab.
You have the S model so it could potentially be occurring via the shower or possibly leaking at the pump connections behind the access door in the shower area. It's not to say that you don't have a leak beneath the cabinet, but maybe the water is leaking in the shower area and flowing underneath your cabinet? If the water is beneath the cabinet area I would suspect that it also could be leaking from the faucet fittings where the water lines screw onto the faucet fixture threads at the sink and water could easily be running down the line onto the floor beneath the cabinet. I doubt that there would be any fittings under the cabinet area and would suspect that it is originating at the faucets (and then running down and pooling beneath the cabinet) or potentially in the shower area via the shower (running underneath the shower), toilet water supply, etc.gbell said:New question regarding city water and cabinet. . We are in Wyoming camping with city water and even with a regulator on we found a water leak. Exacty where I don't know. Unfortunately it is under the cabinet bottom shelf of our t@b max s 2016. And some under toilet area that I could feel.I don't think it was for long but long enough. I turned off the city water line etc and dried out the cabinets as well as possible.
How can I possibly get under the piece of wood too see what is going on. None of the water lines that I could see or feel were wet, so it must be under the wood shelving somewhere. One thought I had was could it have run in from the entrance port? Because of too much pressure, even with a regulator?
Any ideas would be great.
Does anyone think that I could use the fresh water tank and lines, and pump or could theses be compromised? 2 week trip. Ohhhhh.
They build the trailers and assemble things during the build. They also do various repairs and trouble-shoot the trailers and know them inside and out. They will figure things out and repair the issue.gbell said:I am afraid it could be behind the toilet area. How in the world would they fix some place like that?
