this would be pretty simple to install and cheap. Met another TAB owner that says he loves his and wouldn't to without it. I'm new at this- haven't picked up my new TAB yet, but will next week.
https://www.etrailer.com/Weight-Distribution/Curt/17200.html
0 ·
Expect to see a few dozen questions from me in the near future. I'll do a search first.
A suggestion might be, if the trip from the dealer to home or parking spot is short, pull it and see what you think after
Huntington LI
However, I found this on page 408 of our manual..
It says to use a sway control device for over 2000 lbs.
So, I'm not really sure what to make of it.
Our tongue weight is 10%, and the manual says it should be in the range of 9-11%.
Our tongue weight is about 225 and total trailer weight is about 2265.
Sold 2023 Tab 400
Sold 2018 T@B 320S
Sold 2023 Tab 400
Sold 2018 T@B 320S
Lots to consider.
I'm also wonder what the limitations are, in regards to ability to make sharp turns when moving forward. If jack-knifing is the problem when backing up, does that mean the sway bar could also prevent making sharp turns when moving forward as well?
Odessa, Fl.
Odessa, Fl.
I tow with a short wheelbase vehicle, and after having a few uncomfortable sway incidents, installed the friction bar. Every trip is different as tongue weights go, even during a trip. Bikes, no bikes, spare on front, spare on rear, full tanks, empty, etc. The sway bar helps, and I don't have to think about it. I've put new shocks and springs on recently, so who knows, maybe I don't need it at all now.
As for backing up, I don't disconnect unless I see that I need to make a sharp turn.
Most times the sway is my fault for driving too fast, I'll admit. But bad roads, ruts in particular, have caused some weird, unexpected movement. Like everything, it depends on your TV and your conditions, not to mention the current condition of your vehicle.
2022 Ford F350 Tremor | 2022 Cirrus 620
