Hi all...new owner of T@B 320 with many questions. When traveling and stopping for a period of time but not at a campsite, is it best to unplug so it won't run down my car battery? I have read the fridge with drain it..or is there a better option? Thanks again...I apologize about all of these questions..:}
2017 T@B 320S, 2011 2WD Honda Pilot, Coming out of The Woodlands, TX....Mark & Carolyn
0 ·
Some tow vehicles turn off the charge line when the ignition turns off (isolation relay). If yours does not, best to turn off the frig if on DC.
The clamshell Norcold on DC is more efficient - 4 amps/hr vs 11 in the S. I think short breaks it would be okay to leave the frig on.
My 2017 Toyota Tundra has a 150 amp alternator, which came with the towing package (rated to tow 10,300 lbs., so way more than I need for my T@B.) I did a quick Google search on your Honda Pilot and it looks like it may have a 130 amp alternator. I think I read somewhere on this forum that someone had a Toyota Tacoma that had that size alternator as part of the tow package for that model, so yours may be sufficient. HOWEVER, I do not know what the recommended size alternator is for keeping up with the power needed to charge a trailer battery. I just know that mine has been sufficient.
If you don't get an answer here, it might be worth checking with a Honda dealer and/or do a more extensive Google search to see what you find. A good RV dealership, towing equipment installer, or battery shop are also good sources to check with. Sorry I can't be of more help.
A COUPLE MORE POINTS TO CONSIDER: It would be helpful to others if you can identify the year and model T@B you are pulling, plus the size of your Honda Pilot engine. It is a good idea to add that info to your signature settings for this forum so that it appears on all your posts, but also include that info in your question heading so people know your specific situation. Additionally, you should find out how your 7-way wiring is set up. You want to make sure that it has a charge line (sends power from your tow vehicle to the trailer) and will in fact charge your trailer battery while towing. Also, confirm that there is an isolation relay switch included in the wiring connection so that when your tow vehicle is not running, but still connected to the trailer, the trailer battery is not pulling power from your tow vehicle battery and running that one down. (Hope this info helps.......Greg)
https://www.amazon.com/Renogy-Battery-Batteries-Multi-stage-Charging/dp/B07Q4SVX3M/ref=mp_s_a_1_3?keywords=renogy+dc+to+dc+charger&qid=1563936866&s=gateway&sprefix=renogy+sc+to&sr=8-3&th=1&psc=1
Of course you could travel with the fridge on propane, controversial as it is, it works just fine.
https://www.onallcylinders.com/2015/03/27/alt-text-5-things-you-should-know-before-using-a-high-output-alternator/
That being said, voltage and resistance are what determines the current (amps) sent to any connected device. The charging voltage for your TV battery and your trailer battery are the same for the same battery chemistry. If your TV alternator voltage is not high enough to charge your trailer battery then it's not high enough to charge your TV battery. If there is so much current load on the TV alternator that it can't keep up, then the voltage will decrease which is something you will be able to see on your TV voltmeter which most vehicles have these days. Assuming that is not the case unless you are driving an ear damaging 500 watt audio system in the TV or have some other power hog running, the only thing to impede your trailer battery charging is the resistance presented in the charge line wiring and connector. In the article presented earlier in this thread you will see a chart for reccomended wire gauges/line length. Using that chart you would require an 8 awg line to your tow harness which seems unlikely and I am unsure if the 7 pole trailer connector can accommodate that size wire. The trailer wiring would have to be the same gauge as well particularly on the Tab 400 with the batteries in the rear of the trailer. With enough inline resistance the voltage drop could possibly fall below the required level to provide charging to the battery. It is absolutely necessary to clean the trailer connectors, both sides, on a regular basis to be sure that is not exacerbating the charging problem. Stranded copper wire in 12 AWG has a resistance on order of 1.6 ohms per 1000 feet. For 8 AWG it's 0.64 ohm per 1000 ft. Assuming a 10 amp charging current, the voltage drop for 12 AWG wire is 10*1.6/1000 or 16 millivolts per foot. Assuming a total wire length of 35 feet, TV length plus trailer length, would result in a voltage drop of 560 millivolts or just over half a volt. If the TV alternator is outputting 14.6 volts, fairly typical, then your trailer battery would be seeing about 14 volts which is probably adequate. Using 8 AWG
wire would reduce the voltage drop to about 0.25 volts and the battery would see approximately 14.35 volts. Again, every wire connection in the path from alternator to trailer battery will present some resistance. It is very important to make sure all of those connections are clean and tight. Measure the voltage across the trailer battery with your TV connected and running (you need to raise the TV rpms above idle as alternators typically output lower voltage at idle) and if it's less than 14 volts, you need to check voltage at each connection to determine where the voltage drop is occurring.
With other loads running, like the 12V refrigerator, that current needs to be added to the battery charging current to arrive at the potential voltage drops. Measure the voltage, it will tell all.
my battery is fully charged when we get to the campsite and my fridge is cold which is the goal. correct?
there is no one way. find what works for you.
