Installation of Sofitel Sink
teztab
Member Posts: 99
I’ve just upgraded the sink in our 2018 320S with a Sofitel-style stainless sink and glass lid. When searching the forum for any information, I found references to other members having completed this upgrade but no details, so I thought it might be helpful if I posted my installation experience.
The new sink is a Dometic / SMEV VA8005 which I purchased from Amazon for $219 + tax. Installation took only about one hour, although that was made easier and quicker because I had previously fitted a Hepvo trap and flexible connector for the existing sink.
Removal of the existing sink was easily accomplished by unscrewing the four corner clamp wingnuts and breaking the fine caulk bead. The faucet was then easily removed from the counter. Since they both fit, I chose to transfer the drain and faucet to the new sink.
Perhaps the most critical part of this upgrade is the precise measuring, marking and cutting for the enlarged opening of the new sink. There is minimal room for error. I used masking tape to map out the opening. Keeping the front edge of the existing opening I cut the sides, back and corners. I offset the new opening slightly to the left, to allow for the close proximity of the right inside cabinet wall and used my cordless jig saw for the cuts.
Since part of the existing faucet hole is exposed, I used epoxy putty to fill it (although the dark gray of the putty does not look so awful, I do plan mixing a little acrylic paint to match the counter top). After checking for fit, the sink can be positioned and anchored down with the corner screws which are accessible from the top by removing the four rubber pads. Note, there are four tiny clamp extensions that should be fitted before dropping the sink in the opening. Once the sink is secured the water lines and trap can be connected. The final step is to run a fine bead of caulk around the sink (I used GE clear silicone).
The attached photos should be self-explanatory. I am very pleased with this upgrade. The end result is a flush, streamlined look and increased counter top versatility. BTW, if anyone is in need of a standard sink and T@b inset board, I have them available in as-new condition!
⁹
⁹
9
Nice lookTV- '16 Chevy Colorado LT Crew Cab-DuraMax
2018 320S Outback1 -
Really nice work. Thanks for the write-up!
Well done and good instructions!Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio1
yeah- easier to install a new sink than to clean the old one.
Silver on Silver, 320S '19 Outback0 -
Looks great ! The counter top will be a much "larger" feeling space now !
Luckily for us ,our standard 2019 320s (non Sofitel) , came with the Sofitel sink upgrade option .
Makes that counter space much more usable, although I think the Sofitel sink is actually a little smaller than the standard sink ? Any confirmation to that Tez ?
One nice benefit to getting the Sofitel sink option from the "factory", is we still got the "T@B" cutting board !
Some may not notice in your pictures, but the Sofitel sink has the faucet inside the sink , vs outside on the counter with the standard sink . ........... There is NO going back now !!!!2023 Ford F150 Sport 3.5 Ecoboost
2019 NuCamp T@B 320s Grey / Black - SOLD1 -
No doubt you will thoroughly enjoy the change!Stancil Campbell
2011 T@B
Rockingham, NC
Very nice. At some point, I can see me possibly doing this (as well as the plumbing modification). The sink in my 2018 has no cover and, for much of the time is just wasted space.
2018 T@B 320 S Boondock | 2015.5 Volvo XC60 T6 AWD | Seattle, WA, USA
"Blessed are the curious, for they shall have adventures.”― Lovelle Drachman0 -
@PNWtabber A cheaper solution in the meantime until you decide to tackle this project: https://smile.amazon.com/gp/product/B000EDUUGM/
This cutting board fits the sink perfectly and doesn’t budge in transit. Many 320 owners also choose to replace their faucets, if the stock one bothers you.2019 320s BD Lite, white with blue (“Haven”)
Pacific NW1 -
Thanks, @VictoriaP. Looks like a good solution for the near-term. I have been looking at various cutting boards online. Good to know this one fits!2018 T@B 320 S Boondock | 2015.5 Volvo XC60 T6 AWD | Seattle, WA, USA
