I've searched the forum, hoping for a new idea. We got our new tow vehicle, a Tacoma. Upgraded from an older Tacoma. New Tacomas have a deeper tailgate so using my old hitch ball mount the tailgate hits the tongue jack post when lowered. Options:
1. don't lower tailgate with trailer attached
2. longer ball mount
3. mod jack into removable
4. remove jack.
Since the trailer is brand new and I'm not into hokey mods that kill trailer value, #3 and 4 are probably out. Since I have hitch and tow capacity allowance with the truck I'm leaning to # 2. Has anyone experienced similiar clearance problem and how was it overcome? Thanks.
Odessa, Fl.
0 ·
Alan & Patty
Southern Az
https://jack-e-up.com/
Odessa, Fl.
- Basic hitch extender, widely available in various lengths (will have a negative impact on hitch load capacity)
- Jack-E-up which allows you to remove the tongue jack (but requires the jack to always be removed)
- Ultimate Jack which allows you to easily drop the jack to clear the tailgate or, if necessary, remove the jack completely
https://www.etrailer.com/Trailer-Jack/Ultimate-Jack/322-RDJ-2K.html
I fitted an Ultimate Jack to my 320S and i am extemely pleased with the device.
I have a 2017 quad cab Tacoma and use a hitch extension. I have a 2016 CSS and my tongue weight is about 218 depending on how full my propane is. I'm very comfortable towing with it and I only notice the slightest bobble from qusting quarter side wind or from an occasional 18 wheeler. I might have that anyway, I don't really know because I never towed with a standard length hitch. I believe my extension is 18 in. Hope that helps.
CURT 45260 Class 3 Trailer Hitch Ball Mount, Fits 2-Inch Receiver, 7,500 lbs. GTW, 1-Inch Ball Hole, 2-Inch Drop, 3/4-Inch Rise
for extending my ball from the tow vehicle, I am not an expert but have read that hitch extensions which extend your existing ball mount decrease your tongue weight in half. There appears to be no such decrease for the unit from Amazon. My tailgate opens fine unless the I am parked with the front of the truck up and the front of the trailer down (I hope that makes sense). Being able to open the tail gate once properly parked on level ground was a plus as I originally did this to give me more turning clearance as I added a 60 inch box to the front of the T@B 320 Outback. The box protrudes forward of the Outback platform reducing the turning radius. I recently took this on a 3000 mile trip and had no issues.2017 Toyota Tacoma Offroad
Bishop, CA
Springfield, MO
Odessa, Fl.
Odessa, Fl.
CURT 45260 Class 3 Trailer Hitch Ball Mount, Fits 2-Inch Receiver, 7,500 lbs, 1-Inch Hole, 2-In Drop, 3/4-Inch Rise
by Amazon.com
Learn more: https://smile.amazon.com/dp/B0007M308U/ref=cm_sw_em_r_mt_imm_awdb_GSKAVX89NV6NAKZBC6QF
Hitch extenders are a terrible idea.....
WilliamA
2017 T@G XL
A better solution is to extend the tongue, assuming the frame rails can handle the increased moment load on the trailer.
