I'm putting this under Factory Comments but maybe a fellow tabber can answer in. Is it possible to swap the bottom adjuster screw around the opposite direction? It seems pressed in. And no, it won't go in from bottom up. If I could swap it around I could lower the table to a reasonable height without jamming in the fender flair. This is a 2018 Boondock. Thanks.
Odessa, Fl.
Odessa, Fl.
https://tab-rv.vanillacommunity.com/discussion/3608/lagun-table-pedestal-mod-amp-outside-use/p1
2024 NuCamp T@B 400 BD, Charcoal / White
