Mobile Al we get a tremendous amount of rain and now it is dry inside. This is not for everyone but it sure stopped the leak. Even the wet area inside had dried up and gotten MUCH brighter. I wish I could have made it look better, but in this 100 plus heat at least I stopped the leak! Art
Adventures: 58 Nights: 405 Towing Miles 50,180
If all that is not possible most likely would clean off as much of the old sealant as possible from handle base edges back out the screws I can reach then use new sealant on each screw as they are driven back in and finally put a nice bead of sealant around all the handle base edges.
And Yes, the light fixture screws need sealant . . . black stuff tends to be reusable . . .
However Wires use a cable pass-thru clamp {can't think of the correct name} that includes rubber seals; would just confirm it is tight.
For others needing to do a quick repair like this to keep further damage from occurring, silicone and 3M 5200 are both problematic for different reasons. 5200 is the right material in that it’s polyurethane based, which is what nuCamp recommends, but is basically non removable...it’ll never leak again, yay, but you can’t easily go back and clean it up later either. 3M recommends the 4200 instead of 5200 if there is any possibility of eventually needing to remove the sealant.
Silicone isn’t a permanent fix as it eventually degrades or separates from the surface and doesn’t stick well to fiberglass, but it’s also virtually non removable as there will always be a residue left behind that nothing else sticks to either.
Obviously dismantling the area before resealing is best, but it might make sense to keep some 3M 4200 or the equivalent on hand in case emergency repairs are necessary, such as discovering a leak during a multi-day downpour.
