1. Hooked up to 30 amp pedestal with surge protector, 30 amp extension cord attached to  T@B 400.
2. Turn on 30 amp at pedestal
3. No 30 amp power in the camper.
help...it’s cold here in Radium hot springs Canada
suggestions for solving issue would be appreciated
                0 ·
We lost power overnight in Acadia last week and because of the surge protector lights and our power cord light, we were quickly able to determine that it was a campground power problem , and not our T@B . They just had to reset a breaker , but they wouldn't have known if we didn't inform them.
2024 NuCamp T@B 400 BD, Charcoal / White
Is your battery switch turned "on" ? This wont effect A/C powered appliances, but it fools a lot of people because 95% of everything in the camper is 12v powered .
Jeannie
Could be a bad power cord I guess ? My power cord has illuminating lights on both ends so I know if it has power at the feed, and all the way at the camper , so I know if power is going through the cord . Yours may too ?
Why not Contact the camp owner and have them check the pedestal........ Could be as simple as a tripped breaker on their end
is the light in the power cord on now?
from these post I would assume it was the cord from the campsite pedestal to the camper.
I would guess easiest would be to unscrew from side of camper and pull out, but not sure NuCamp left enough wire slack to do that?
