I know I am not the first to mention the Ultimate Jack but I thought other forum members might be interested in how I modified and use mine, especially since there have been recent jack discussions concerning accessing bike racks and tailgates, etc.
I purchased my Ultimate Jack a few months ago from Tractor Supply for around $70. It is top wound and can be easily raised and lowered to various heights with the use of a sprung locking pin. Although the manufacturer does not promote the complete removal of the jack, it can be accomplished by releasing a side bolt that protrudes into a vertical location groove.
As I hope is evident from my pictures, I removed the wind handle and replaced it with a 1/2" socket that I drilled to accept the existing nut and bolt (if necessary the handle can easily be reinstalled at anytime). Not only does this allow me to wind the jack with my power drill, it also makes the jack more compact. I also adapted the side channel release bolt with a large hand screw that allows me to quickly release and remove the jack without the need for a wrench. Additionally, installation of the jack to my 320 tongue required some modification of one of the three jack bolt holes.
Since we carry our bikes using a hitch adapter, I can at any time quickly remove the jack, which means less risk of damaging the bikes and easier releasing/tilting of the bike rack to access the rear of my Trailhawk. Previously, I was using the original jack modified to operate with the drill from the rear. Although that worked, the Ultimate Jack is so much easier and gives complete reassurance, especially in tight turns. Of course, when not transporting bikes, the UJ can be easily put in a raised position and left in place.
Incidentally, if any member could use my old jack (2018, 320) modified for drill use (I can set it for front or rear winding), they can have it for the cost of the shipping from NY.
2011 T@B
Rockingham, NC
2013 Tundra TRD 5.7L
Massachusetts
I'd be curious to see how your bikes are mounted.
I assume that this means one of the holes was in the wrong place for the Ultimate Jack. How far off was it? How did you deal with it?
I really like your idea to use a knob in place of the retention bolt for the jack's plastic tube guide. I wish the groove on the jack's outer tub didn't require removing the guide to allow full removal of the jack from its mount.
2023 T@B 320 S Boondock
I put using a power tool to drive a mechanism designed for manual use in the same basket as adding that hitch extension. Fine for someone else, but not me.
