I recently brought home my new 2020 Tab 320 S and have been going through the manual (2017, and I really wish there was something more current than that!) I've also been going through the posts here and on FB and it's all been helpful, but as a first time RV owner I still have questions that I cannot find answers to.
First is the toilet, right now I have all the water drained from camper because I knew that it would be sitting for around a month, so the toilet has no water in it. I read somewhere that "you should keep water in the P-trap so that you don't get odors from black tank" First of all I'm not sure what the "P-trap" is, and second, is this true, and if so do you always, other than when you winterize, keep water in this P-trap? I also read that there should always, again not during winter, be some water in your black tank. True or false? Last question, on the chemicals that you add to toilet for deodorizing and cleaning, do you also put some down the sink drain for the gray tank?
Next questions are on things that I either read in manual or from here, but were not explained in detail. The manual says to "drain all low lying drain valves, but does not tell you where they are. I know there is the black, gray and fresh water drains, and the yellow lever in the Alde, and the outside shower, but are there any other ones?
I have read about bypassing Alde when sanitizing, and found a nice labeled picture of the correct position of valves when sanitizing, but it's from a 2016 Tab and my 2020 looks a bit different. So I'm a bit concerned about that because I cannot be certain that I'm going to find the correct valve. Is there a picture somewhere of the current Alde setup?
Next question is about the 2020 Elwell air conditioner, where are the filters? I know your supposed to clean them every now and then, but where are they?
My last question is that I'm going to go on my first camping trip in the next few weeks and right now I have all the water drained from tanks, should I sanitize before trip?
thanks in advance for any help you can offer!
North Texas
2020 T@B 320 S Boondock Lite, 2020 Chevy Colorado Z71 4wd, V6, Crew Cab, tow package
0 ·
1. In addition to always keeping liquid in the P-traps, I would also recommend to keep some water in the toilet bowl (camping season) and antifreeze in the bowl (winter) to prevent rubber seals/gaskets from drying out.
2. During camping season, during and in between trips, we always put a gallon or 2 of water with Happy Camper enzyme in the black and gray tanks to let it deodorize and breakdown any left over residue. In winter, we drain the tanks, then put some antifreeze down and make sure to open and close the tank valves to displace any water in the valve area.
3. Regarding always having water in your black tank, you want the tank to fill (instead of letting the tank valve remain open) so solids don’t cling to the sides. Also, if your black tank is only partially filled when you go to empty it, fill it to at least 3/4 full to help prevent solids from getting hung up on the side of the tank.
4. You named all the correct drains. The only other drain I can think of is for purposes of glycol exchange - not used routinely.
5. The plumbing has not really changed as far as I know. I suggest you locate your valves and label them. If you take a picture of your valves, we can help you label them. Bypassing the Alde involves turning the bypass valve parallel to the pipe to allow water to flow through the hot water (red) plumbing lines and turning the hot and cold water valves to the off position (perpendicular to the pipe) to prevent flow into the Alde.
6. I saw a video where the Air8 filter was on the side of the unit. If I remember correctly, you just slide it up.
7. If you have not sanitized this season, you should sanitize. Also, be aware that there may be plastic debris in the plumbing, so clean the water pump filter at intervals.
Hope this helps.
I still cannot completely wrap my head around them though. I did a Google search on P-traps and now have a general idea of what they do, but I do still have questions:
Do you just pour a little water down the drain and your done? Same with the toilet?
If your not using your Tab for a while, do you pour more water down the drain to change the water in the P-trap?
During the winter when you have anti-freeze in there, do you add more anti-freeze every few weeks (one Google search said to do that)
If you are using the alcohol based one, it’s probably worth tracking down the propylene glycol based instead. It is more expensive though. Home Depot carries it under the brand South/Win.
https://youtu.be/KRszDLne1l
