Broken Handle
mandt
Member Posts: 158
I need to replace the broken handle. Can someone point me to where I can buy the assembly... preferably
Amazon.
Amazon. Mickey & Terri
2016 Max S
Kalamazoo Michigan
2016 Max S
Kalamazoo Michigan
I have the same repair pending but have yet to order the part. I plan to remove the broken handle after I winterize and figure out the thread size. Amazon has several, including metal versions.I'll post back here when it's fixed, unless you beat me to it. ;-)2015 T@B Max S (320)
Just file/finish the broken edge of. It looks like a weight saving mod. You shouldn't need the leverage of a two handle, and I never understood why the handle is so big anyway.
Odessa, Fl.
Not sure I would replace it with metal as I would rather the handle break than something less easy to change deeper in the plumbing.2009 GMC Canyon, 3.7 liter
2020 320s Boondock lite, With Lots of mods -
Yeah, despite my intentions to make the repair, lazy reality says I'll probably leave it as is since it still works just fine. :-)GatorEgg said:Just file/finish the broken edge of. It looks like a weight saving mod. You shouldn't need the leverage of a two handle, and I never understood why the handle is so big anyway.
The actual valve nuCamp uses is the La Salle Bristol (rather than the far more common Valterra, for some reason). Amazon doesn’t seem to carry just the handle, so if you want an exact match, you’d have to buy the whole set. https://smile.amazon.com/gp/product/B003VAYXR2/
The Valterra or Camco replacement handles should still fit though.2019 320s BD Lite, white with blue (“Haven”)
Pacific NW -
Thanks VictoriaPMickey & Terri
2016 Max S
Kalamazoo Michigan -
Amazon to the rescue!. They apparently now carry just the handle for the valve. The one on my 400 just broke.VictoriaP said:The actual valve nuCamp uses is the La Salle Bristol (rather than the far more common Valterra, for some reason). Amazon doesn’t seem to carry just the handle, so if you want an exact match, you’d have to buy the whole set. https://smile.amazon.com/gp/product/B003VAYXR2/
https://www.amazon.com/gp/product/B007HRMZC0/ref=ox_sc_act_title_1?smid=ATVPDKIKX0DER&psc=1
2019 T@B400 Boondock Lite "Todd"2016 Toyota Tundra 5.7 Crew Cab
- 916 Introductions
- 72 Teardrop Groups & Links
