Since I brought home my new camper it's been plugged in with battery on. Never got the chance to examine the fridge until more than 2 days ago. Turned it to the plug sign and temperature all the way up. The little green plug also lit up. But it has not been cold at all! There is hot air venting out from the top vent and the camper is also leveled. Have not tried to use propane yet thinking that most times I will go to campgrounds with hookups. What's the deal here? Newbie is lost...
Tent to trailer w/TV: 2019 Jeep Grand Cherokee High Altitude 3.6L
2019 Tab 320 S Boondock Edge and get me out of NYC!!!
0 ·
There is a separate thermostat control for electric vs. propane. Are you using the correct thermostat control for the power source you are using?
Turn off whichever thermostat control is not currently being used.
Also, don't set the applicable thermostat for the power source you are using all the way to the highest setting to start the cooling process..........maybe set it 1/2 to 2/3 of the way toward the coldest setting first. I'm not sure that will make any difference, but it might. (Greg)
https://us.v-cdn.net/5021717/uploads/editor/km/hagzgl7hkh71.pdf
(Alde: 3020; Refrig: Isotherm Cruise 65 Eleg; Battery: BB 100Ah LiFePO4; Solar: Renogy 220W Portable Suitcase; Victron BMV-712; Pwr Cntr: PD-4135KW2B; EMS: PI-HW30C)
2024 NuCamp T@B 400 BD, Grey / White
What I don't understand is that either AC or propane, the fridge seems 'normal' with hot air coming out of the top vent and I can hear the 'liquidy' sound when I open the fridge's door, if you get what I mean.
Is there anything I am able to check through the top and bottom vents for defects or something 'abnormal' ? My last resort will be to do what @ScottG has mentioned above...
Thank you.
Please do report your findings.
If the countertop on the right hand side gets warm to the touch, the insulation is falling down blocking the top exterior vent slightly or completely and the countertop will get warm, and the fridge wont work so good . Solution is to re-glue the insulation board back in place.
Looks like that is not your problem.
Leveling is VERY important with these finicky norcold fridges . If the front of our T@B is slightly elevated , the fridge just wont work . All kinds of heat and burning smell coming out of the upper vent though ......
Make sure your T@B is level, or even slightly nose down and see if it works any better .
NOTE: I hate these 3 way norcold fridges nuCamp is using , and will likely try to swap mine out with a nice compressor style 2 way fridge in the future. They are $$$ , though !
It may be that you are due a replacement refrigerator, which is what I would be demanding if Norcold (or nuCamp) cannot resolve the issue. I am following this discussion closely, because I am very interested in how it all turns out and wish you all the luck with what you are dealing with. Very frustrating.
Many, including me, have had problems with the rubber seal repeatedly falling out of the channel on the inside edge of the door within which it rests. During my last trip (two months long), it was continually falling off due to absolutely no adhesive present to hold it in place. Sometimes, the seal was misaligned, which could quickly let out all the cold air. I could not fix it until I got home, because I was using the refrigerator daily.
The proper way to fix the loose seal is to remove the door (very easy.....just remove the screw at the top right corner of the door and lift the door up off the pin it rests on at the bottom right corner of the door), lay the door flat on it's outside panel, and apply small amounts of adhesive (I used Amazing Goop II) at a few spots along the seal before reinserting the seal in the door seal channel. You do not need to put sealant along the entire length of the seal. I recommend against putting on too much sealant, because you never know when the rubber seal may need to be removed and replaced due to damage.
The "loose seal" issue is a known problem, so it boggles my mind that Norcold and nüCamp have not addressed it. Such a simple and inexpensive fix. Thank goodness we have bright minds on this forum who are willing to help each other out with issues like this.
https://tab-rv.vanillacommunity.com/discussion/7717/norcold-3163-3-way-refrigerator-wont-start-on-propane-what-fixed-mine-general-diagnostic-advice
ALSO.............read p. 7 ("Troubleshooting") of the attached .pdf document, which is from the above thread. It is a Norcold service manual for another model refrigerator, but may describe what you are experiencing, and the potential resolution.
@Bayliss, it's funny what you have said about the gasket. I noticed that even the first time I saw the camper on dealer's lot. Looked like a crooked picture frame! But again thanks to the great people in this great forum that I have been forewarned ahead of time! Long story short, that was the first thing I did when I brought the camper home, before I even had time to mess with the fridge(thought that it's a new fridge right? Will get to it later, but who knows!)
Need to scroll back up 'cause I know you already left me more info before I can finish typing. Thanks, @Bayliss.
So as per @JEB's suggestion, turned on fridge about 4 hours ago, shut off propane, turned off battery, switched mode to AC, set thermostat at 3 snowflakes, press the igniter like 10 times, little green plug light is on, leveling bubbles are all in the middle.
This will be my final attempt until I reach Norcold on Monday. I personally do not like time consuming stuff like leaving the camper to dealers or manufacturers, waiting for parts and all the nonsense. Hopefully Norcold is able to fix the problem or replace it, otherwise I will most likely replace it with my existing portable compressor fridge. That will be a project and another topic. We will see...
Thanks.
After all this time of back and forth from camping, individual use of energy source(LP and AC), no matter how leveled the trailer has been, I have gotten no positive results.
Norcold told me that in order to have the fridge replaced or repaired under warranty, I must go back to the dealer where the Tab was purchased. Besides the 5 hour drive to that dealer, there are many good reasons for me not to deal with and trust this dealer ever again. 3 other dealers(within 2hr drive) I have called had told me the same as what Norcold did. One of them was nice enough to go through a few things with me and suspected that the refrigerant of the fridge was dead.
So, inspired by the mod from @GeoMars, I have decided to go that route but the outcome may not be as great...
https://tab-rv.vanillacommunity.com/discussion/6556/replaced-norcold-3-way-with-efficient-ac-dc-electric-fridge
Keep us in the loop with your project (with pics !!!) , so we can all see how it turns out and exactly what cooler/fridge and parts you used to make it work ! Cant wait to see a happy ending out of this !
My 3 way is working marginally enough that I cant quite yet justify replacing it just yet . It did freeze 2 dozen eggs on our last trip though ..........Hmmm , maybe it is time !
