2017 T@B 320 S. Not receiving a charge when hooked up to the TV’s 7-pin. Tested the TV with a multimeter and all is good there. 7-pin plugs are clean. Battery cutoff is turned on and battery fuse is good. Tested fuse holder as directed by dealer with multimeter and showing a charge on the battery side but nothing on the other side. Checked the junction box under the trailer and all looks good. Thoughts for trouble shooting?
Resolution... I took the trailer to our dealer, Elk River RV (MN). They found an intermittent short in a fuse holder on the 12V power line coming from the TV's battery. They replaced the fuse holder and now it works. Also, learned that the TV's lights must be on in order for the TV to deliver 13.7 volts for charging. A shout out to the crew at Elk River - they provided EXCELLENT service, working us in to their already booked schedule. We are so glad we bought our T@B from them. Thanks also to all on the forum and T@B Facebook page who weighed in with diagnostics/solutions.
2017 T@B Max-S, silver & silver, towed by a Titanium Silver 2018 Kia Sorento AWD V-6, Twin Cities MN
2 ·
(Alde: 3020; Refrig: Isotherm Cruise 65 Eleg; Battery: BB 100Ah LiFePO4; Solar: Renogy 220W Portable Suitcase; Victron BMV-712; Pwr Cntr: PD-4135KW2B; EMS: PI-HW30C)
“To help charge a remote (non-vehicle) battery, press the Tow/ Haul Mode button on the center stack. If the trailer is too light for Tow/Haul Mode, turn on the headlamps to help charge the battery.“
Zero problems maintaining a charged trailer battery.
Luck favors the prepared.
Alan & Patty
Southern Az
One of the last things I do before taking off is to turn on the headlights then walk around and double check tail lights, brakes, turn signals, etc. Since I found out my headlights had to be on the check tail lights, I just assumed they had to be on for everything else to work as well. I'll have to check whether my brake and turn signals work without the headlights on.
Yes--I have the factory OEM tow package.
WilliamA
2017 T@G XL
In getting our 2018 Tab 320S ready for the season, our left back turn signal and brake light did not work. As the countdown to travel was on and we sought forum advice, we assumed it may need replacing, we ordered a new one, the Kaper II L15-0021 Red LED Trailer Turn Light, from Amazon.
Preparations were made and further tests conducted. Taking the old one apart and checking it for rust and loose wires, it looked as if replacing this may not prove difficult.
While waiting for its arrival, we sought advice from someone we trusted. We took our unit to Sunwest RV Centre here in Courtenay on Vancouver Island, where we purchased this, and spoke with Erik Vierstra, the service warranty advisor. He went over a series of procedures to see if we could isolate the problem. In order, he is what happened:
1. As the tow vehicle lights all worked, he advised tracking the problem from this on back. He tested the brake/light connector. No problem was found.
2. Next, Erik recommended using dielectric grease (as was suggested by ericnliz in 2017) on the brake pins. I purchased a very small tube of this from Lordco Auto Parts and applied this using Q-tips without success.
3. Just prior to travel, the replacement light arrived and there was no time to install this. As a last ditch effort, I decided to give the dielectric grease a final try. This time, I cleaned deeper and much more thoroughly – it worked!
We all lit up and had a great holiday.
Hope this helps others enjoy one too.
Cheers,
Jim
