Recommended tool and spare parts list?
I searched for "tool kits" "tool sets" " tools"  but did not find a summarized list. I'm new and and looking to put a kit together. I have made a starter list from reading the posts but would appreciate input from the collective experience from the group. I hate those "if I only had a _______ (fill in blank) moments, especially if I'm miles away from the stores
Also, Should tools be SAE or metric or both? (even built in USA can use metric)
Here's some notes I have made so far...
* R1, R2, R3 bits plus phillips, slotted and driver
* breaker bar and 3/4" deep socket plus socket for spare
* blade fuses, glass fuses (see fuse list for newbies)
* duct tape, electrical tape
* cordless drill and socket for raising stabilizers if desired
* multi tester
* spare batteries as needed (AA, AAA, etc)
* flashlight/headlamp
* WD-40
Thanks!
2015 T@B Max CS-S Silver and Black
Goes where it's towed to by 2017 Subaru Outback
    edited April 2017
    Mallet
    Small claw crowbar
    Lithium grease
    DD batteries for O2 fan
    Gorilla tape
    Twist ties (those suckers come in handy more often than you think!)
    Small level
    Misc wire connectors.
    Extra coupler pin
    Extra hitch pin
    Don't use multitools with tiny bits. T@Bs eat them bits for lunch.
    Get real R1,2,3 and phillips and flathead.
    Light test light
    Bandaids
    Extra cords for charging
    Pocket knife
    Small hatchet with sharpener
    Small tube of sunscreen and bugspray (change out every season)
    lip balm
    WD-40
    PS.. I've used every one of these camping!
  • db_cooperdb_cooper Member Posts: 741
    I've found these great for mods it repairs.  I've attached my Rubbermaid container to the platform with them, and just used one to support my gray  water extension.
    Serious Ties - Extra Heavy Duty Cable Ties (50, 24 Inch/175Lbs/UV Black) https://www.amazon.com/dp/B00I0F1AH4/ref=cm_sw_r_cp_apa_mGu9ybG6XWV89
    Bungee cords
    ball bungees
    fold-able shovel
    matches with water-proof container
    long handle lighter- 2 are better
    duct tape
    superglue
    hammer
    crescent wrench
    fuse tester (some fuse kits at automotive stores have these included)
    Small rake
    broom
    edited April 2017
    I always bring all of em....
    that way I'll never need any of em.
    B)
  • 2Cougs2Cougs Member Posts: 925
    Love these lists... The best thing about this forum is 1,000 heads are better than 1
    A lot of the above plus:
    Silicone spray - great for the hitch latch, ball, and keder rail before feeding in an awning/tarp/tent
    Bike cable lock to secure the surge protector at the power post
    Brass 'Y' hose connector at the faucet
    Leather work gloves
    Hand lotion
    Hand sanitizer
    Scissors
    Case cutter
    Tape measure
    Double scissors.. make sure they are sharp and don't rely on the ones in your pocket knife!!
    I always carried a spare wheel hub on a stub mount on all my boat trailers.  Does anyone carry a spare and if so where?
    Odessa, Fl.
  • CarlimmenCarlimmen Member Posts: 10
    Water filter for hose, coaxial cable for tv along with everything else mentioned above. Spare is mounted on tongue jack.
  • tabiphiletabiphile Member Posts: 468
    Channel lock pliers
    Side cutters
    JB Weld
    Torque wrench
    Tire valve kit including wrench and valves
    Tire plug kit
    6 plus feet of wire
    Paracord
    Latex gloves
    Paper towels/rags
  • rh5555rh5555 Member Posts: 531
    We also carry a quality saw for that small tree that's down across your forest service road.
