Very carefully! I screwed the screws in very slowly, knowing that the wires were loose enough in the clamp to move away from the screw. Mine is a 2019 400 and it only had one bundle of wires near the top of the compartment. You’ll have to open the passenger side plywood cover to see where yours are located. I took numerous iPhone photos so I knew exactly where everything was.Michael49 said:Yea, here's my concern - here is a screenshot from a video of a 400 build - looks like there are wires that run through that container box - how do you screw into that box without hitting wires?.....
Thanks - that's very helpful.Verna said:Very carefully! I screwed the screws in very slowly, knowing that the wires were loose enough in the clamp to move away from the screw. Mine is a 2019 400 and it only had one bundle of wires near the top of the compartment. You’ll have to open the passenger side plywood cover to see where yours are located. I took numerous iPhone photos so I knew exactly where everything was.Michael49 said:Yea, here's my concern - here is a screenshot from a video of a 400 build - looks like there are wires that run through that container box - how do you screw into that box without hitting wires?.....
Thanks Denny.Denny16 said:No, the front ply is only 3/8ths, you need to add a 1-inch block to the front, )Extended to the floor will help) but the bolts into the block, and screw the block to the ply front with at least six screws around the edge.
The only way to bolt directly to the ply (and I still would use a 3/4 inch backer board on the front) and the poly backing board that comes with the Lagun Mount, but this requires access to the back of the front panel. Another option, if your power converter is not under the pax side dinette seat, is the mount the Lagun Mount to the front of the seat, access may be available by removing the under seat compartment front liner bit.
The Lagun Mount is a big lever, even with a small table top added, so mount it securely. I Lomé the idea the OP shows in the opening post on pg 1.
Sorry if sound like a complete moron hereDenny16 said:With screws along the two vertical edges, use corse thread wood screws about 1/2-inch longer than the wood block, for example, a 1.5 inch screw on a 1-inch block. You could add some glue for a stronger bond.
, but your screwing these in at an angle/diagonal through the block and then into the 400 ply, correct? Or are you attaching the back of the block to the ply and then building it out as you go?
Verna said:Looks good, @Michael49!Check out the top I purchased from Home Depot for $20. It’s in the tool section and it is intended to used on top of one their rolling tool. Sinners. They have two sizes—you want the smaller size.
Only issue is that it's thick and HEAVY. I think I would need to flatten it with a router - something I've never done, but I'm always up for a new project and Youtube is constantly convincing me to try things that I probably shouldn't.Verna said:@Michael49 GORGEOUS! Ambrosia Maple?Great idea. I would remove the bark, put a couple of contrasting butterflies at the bottom and top where it looks like it will split, and cut a gentle curve where the broken limb section is. Sand and sand and sand, then some clear Watco, two or three coats of wipe-on poly and you’re set for 5+ years!
Verna said:@Michael49 yes, it’s too wide for my planer, so a router sled would be a necessary addition to my tool arsenal! Once it’s down to 3/4” to 1”, the weight should be manageable.
I did use router to flatten it - long job as the widest bit I had was 5/8" - should have bought a nice 1.5" bit but I'm cheapDenny16 said:How long has it been since the crotch was cut? Looks like it is a little green still. A slab like this can be rough flattened while it is green, but should be allowed to dry for one year per inch before finishing it up, as the wood will shift while it is drying.
. So much lighter! Last photo just after applying "Good stuff" wood finish. It was a lot of work but I'm loving it so far.
Michael49 said:
........Wood has aged over a year according to the person I bought it from.
Here's a few photos after shortening, flattening and seemingly endless sanding. So much lighter! Last photo just after applying "Good stuff" wood finish. It was a lot of work but I'm loving it so far.
