@atlasb asked in another discussion for a photo of the T@B 400 frame before the build, so I also took photos of the T@B 320 frame. Please realize the frames are upside down, before the axle is attached:
T@B 400 frame with gray tank in place
T@B 400 with the gray tank and white fresh water tank (soon to be attached)
T@B 400 with gray and white fresh water tanks from another view
T@B 400 with gray water tank from another angle
T@B 320 (upside down without axle) with gray tank and white fresh water tank
Another view of the T@B 320 with gray and fresh water tanks
T@B 320 from a different angle
Are there any photos showing the aluminum framing in the body walls & ceiling?
@rajamar
I see. Now I feel better.
Also, I've never seen any photos showing aluminum framing inside the side walls.
2016 NuCamp 320 T@B Max S
T@bbey Road
Appleton, WI
Seem to recall a post somewhere on this Forum that goes . . .
Close up the T@B, run hot water in the shower, condensation pattern will show metal frame locations
Bottom line is that the beams are evenly spaced 8" apart so if you can locate one decisively you should be able to pinpoint the others.
If you do get condensation inside(planned or
not) be sure to open all cabinets and check the outer wall. Mine were very moist inside the first time I had condensation. I took everything out, and dried
it all out to prevent any mold growth.
With all that insulation, I would expect the inside wall surface over it to be closer to inside ambient temperature & therefore not show as much condensation compared to the wall over the aluminum framing, which would be colder when outside air is cool.
In any case, thanks to all for the helpful replies about locating framing. I have found the ones about 8" OC spacing between aluminum roof supports to be most helpful for getting screws properly located on the inside ceiling for support of cargo netting.
T@bbey Road
Appleton, WI
I would like to see that. Your pics didn't attach.
This is really strange. I do not see any pictures or attachments in either of your posts. Am I not looking in the right place? Usually pictures are embedded in the post.
Aha! It has been cold here and I am a little slower than usual.
Sorry for the misunderstanding—I couldn’t understand why you couldn’t see what was obvious to me and I couldn’t see what was not apparent to you!
