We had to stow our T@B for the first time yesterday and parked it, as planned, in the driveway just in front of our garage. [modding doorway and raising roof of garage so T@B will fit inside is this summer's project!]
Our driveway is narrow and somewhat uphill and the garage is at the back (and I'm not exactly a trailer-backing rockstar) so backing the T@B into place was something of an ordeal. I'm thinking that, in the future I could make things much faster and easier if I had some sort of winch attached to the rear wall of the garage and a way to hook it up to the rear of the trailer. I could then just unhitch from the car at the mouth of the driveway, hook up the winch and use the tongue to steer while applying winch power with a remote. Anyone have a setup like this or have any suggestions for winch-model and/or connection point on T@B?
Thanks!
Ben
Ben Trelease & Eleanor Bell - Seattle, WA - 2009 T@B Bell@luna TV Subaru Forester
0 ·
The only thing I can think of a somewhat secure attachment from the rear, would be the axle. Otherwise, pull it from the front and pivot the trailer in the garage.
Just some thoughts.
One thing about backing the smaller trailers is that it does take practice (and patience) and is best accomplished taking it slow and easy. I know that it is frustrating for many people but one trick when looking over your shoulder is to grab the steering wheel at its lowest point and turn the wheel in the direction you want the trailer to go.
I believe that this is the winch referred to in the post above this one:
Mike
I cannot emphasize enough the need to practice with these trailers, even if it means driving to a remote spot in a mall parking lot with your unit and practice backing it into a parking spot. Slow is better as these units are impacted by any minute movement of the steering wheel. And when you are looking over your shoulder and have your hand on the top of the steering wheel you need to turn the wheel in the opposite direction you want the trailer to go.
Here is a video that will help you out and don't feel bad as we all have to practice and hone this new skill. Backing a trailer up requires patience as I noted before. There are times when I pull up to a potential site and I will get out first, examine the camp site, look for any obstacles and impediments like rocks, tree roots, picnic tables, fire pits, electric pedestal, water hook-up, etc. so that you can mentally gather these things in to eliminate damaging the trailer or the utility, etc. You'll notice also that some of these items have been hit and damaged by other campers as well. Bottom line, slower is best and short movement on the steering wheel and back in slowly as any movement via the steering wheel is magnified.
Check this out as there is some great info here and I do use the scoop as it does make backing in easier.
Hi Mike. Not committed to the winch and thanks for the suggestion about floor mounting it. If I end up going with a winch that is likely going to be the best way to go.
The problem is not really backing up in general - I'm not great at it but was able to get it into camping spots along our trip fairly easily. It's that our driveway is extremely narrow (I'd say there is about 4-6" of clearance on either side with the trailer dead center, with our house on one side and a fence on the other) and the narrow street in front makes doing any sort of jockeying really challenging. Give me a few years and maybe I'll be able to ninja it but in the meantime I want to be able to get the trailer stowed without blocking traffic for 15 minutes :-)
I'm going to look at powered trailer dollies as well. If I can find a used one I might be able to solve the problem that way without paying too much extra $$ and without having to worry about breaking the garage.
(formerly a 2013 T@B Q M@X); 2015 Jeep Sahara JKU (Max Tow)
Toronto ON Canada
I spent 2 months in Seattle working in 1977 (yeah, a long time ago), and a week in 2011 on vacation. I do understand the conditions of the narrow driveways, backing up an Indiana Bell Telephone work van (we weren't allowed to pull into driveways or parking spaces).
I suggest that you go to a parking lot and somehow recreate your driveway....and practice, practice, practice. You will get so much better if you're no longer afraid of the closeness of your driveway. No one keeps track of how many times we need to pull up a bit to straighten up. Whatever it takes to get your T@B into your garage, is worth not hurting yourself with a winch.
The Silver Shadows and the 4-wides (my experiences) have a much shorter tongue in relationship to the body and length of the T@B's. Trust me....the T@B's are somewhat easier.
Oh, and by the way, when I got back after driving 11 hours in one day from my return trip from Arizona, it did take me 3 times to get backed into my driveway. It was dark, two cars were waiting patiently for me to get backed in and I couldn't see because of the darkness and how tired I was. I was angry because I normally "nail" my driveway the first time, although I don't do it in a completely straight line--it's hard with such short tongue lengths.
Good luck......practice, practice, practice!
https://www.youtube.com/watch?v=JvyU6KwptAA
mike
I don't know Mike, this one is pretty dang McGiver-esque...
My driveway is fairly short but steep and the tab needs to go to the side of the drive where there is no "ramp" up the curb. I back her in as best as possible then attach the winch cable, chock the wheels, and unhitch. I had to go with a hand crank winch as there is no electricity out there. So..., i aim and push her in the direction i want, crank the winch, aim and push, crank. Repeat. Its the only way i can do it alone. Tedious for sure but gits er done. I'm thinking about running power out there and going with an electric with a remote. (my original plan). Had to get this done quick so went with a $30 winch from harbor freight.
My wall is cinder block but the blocks are filled with concrete. Took 2 days to drill the mounting holes. Bolts go all the way through and have several GIANT washers on the back side to spread the load.
Works beautifully
mike
But I think the one with the hand-crank would be easier on my rocked-out, over-sensitive ears.
Since I'm still deciding on whether, or not to go T@B and closely studying all of the great information all of you provide (THANK YOU ALL!), I was wondering about garage storage. Will the T@B it into a standard height garage? What is the actual height, from ground to top of vent, of a T@B?
My thoughts are, if need be, remove the T@B wheels, and lower it onto (Harbor Freight) wheel dollies. However, there's always a possibility the T@B may still be just a bit too high and end up being stored outside in the Florida sun, which is a NO GO for me. Would love to hear from all you current T@B owners about this.
www.purplelineusa.com
So now I simply drive the T@B in with a remote control
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL
At a Teardrop gathering, we were camping at the top of a crazy wet slope and the land owner used his (relative new) medium-sized tractor to pull the teardrops up the hill (somehow I made it up the hill in my Rav4 + LG Reverse TD). I've pulled things upwards on a slight slope with an old (yet medium-sized) narrow-front-wheeled tractor and could feel the front end lift a bit. A tractor mower would work for slow level pulling, but I'd cringe if I saw one used to pull a nearly #2000 T@B (I know some are lighter) up any sort of slope.
I have to back the Tabitha into an 8 ft wide (yet short) driveway that has two fence posts on either side and miss the Harley Softail Deluxe that is parked in it. I have to go in at an angle so the tail end of the T@B doesn't point towards the chainlink fence running nearly flush to the driveway on one side. It's doable and it's all about practice. It doesn't help if someone has parked their car across the street in front of my driveway either. It makes almost for a right angle driver's side turn. The key for me is to remember to remove the stabilizer bar!! I didn't have one on the popup I had for 13 yrs or on the LG Reverse Teardrop. The Tabitha tracks so well, I forget the stabilizer bar is on the hitch.
Each TV is different and reacts differently to backing up. If you are that concerned, give the purplelineusa people a call and ask if their system would work for you. Like I said, it looks really interesting and their website said there was a lifetime guarantee on the rollers.
Let us know what you end up doing!
I know it's all about practice, but, I still have a parking issue to overcome. My driveway is steep and sloped towards the street. My current technique is to drive forward up the driveway into the garage and then have a friend help me detach and swing the T@B just behind the second garage stall on the far left. When I don't have a friend, it has to be parked on the street, temporarily. Right now, backing it up mostly results in jack-knifing and I have watched the video Mike posted. I was thinking of investing in a trailer dolley, so I could attach and detach myself, but not sure whether it will work. Of course, my biggest fear is the T@B getting loose and rolling down the yard. Any advice or recommendations are appreciated.
Minnesota
Practicing to be a wanderer
2020 T@B 320 CSS Boondock Lite
2014 T@B 320 CSS M@xx
2020 Jeep Wrangler Unlimited 8 speed automatic
2020 Jeep Grand Cherokee Limited V8
2018 Jeep Wrangler Unlimited Rubicon 6 speed manual
By the way my driveway is not long, but it is very steep and has a compound curve that makes the parking a challange. I view it as a fun challange and don't get rattled even if the neighbors come out to watch. Many a time I pull all the way out and start over. The best advice I got was to remember that the little trailer turns very quick, sometimes to quick, so easy short corrections to the wheel work best.
MOUSE-KE-T@B
Harvest, AL
