being new to tab, boondock edge, at a rv campground, how do you know what is the correct power plug in for your tab. i know 220 is a no, no. are they labeled in the box? i know what 110 looks like, thanks, not an electrician.
2018- 400- Colorado V6-Marin MT bikes
0 ·
I run my T@B 320 on household 15A just fine; in summer A/C works and in cold weather Adle works (at 1kW). Not sure I could also run a dry dryer but that's not a big deal at home.
At least once while traveling had to use 15A 110VAC instead of 30A connection (30A was dead) . . . T@B was fine the entire visit.
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL
Propane works just fine.
Alan & Patty
Southern Az
[2] As noted in earlier post. I've had no issues operating the T@B on a 15Amp circuit . . . just remember that you have limited power capacity. When doing projects at home T@B is on a 15Amp circuit with 120-feet of extension cord and the A/C or Alde plus an electric drill all work fine. But I only do so for four hours, am not using an extension cord for long periods of electrical power.
[3] Would be helpful to use correct terms as you describe what your issues/plans are.
Standard Household Outlet; 15Amp 110VAC
T@B power system (and cord); 30Amp 110VAC
Campground Power Post Options; Any combination of
15A 110VAC
20A 110VAC {breaker with 15A style outlet}
30A 110VAC
50 A 110VAC
Your focus when matching electrical cords should be on the current, Amps, not 110Volts.
MOUSE-KE-T@B
Harvest, AL
I think it was about $50 worth of parts (depending on your breaker brand).
There was a weatherproof box with a 30A outlet in it, that was around $30 at Lowes.
The breaker was around $5, but it didn't fit my breaker box so I had to go to Home Depot and the correct one was $10.
The 10 gauge 6 foot wired pigtail was around $15.
I purchased a 30A 50 foot extension cord to reach the outlet, but I was going to buy that anyway for those hard to reach power poles.
Tampa FL
As a result our T@B has served as an add-a-room during the summer with the AC on occasionally, as well during the winter with the Alde running and snow on the roof.
Tampa FL
This is our electrical set up at home. I had an electrician install the 30 amp service. I could have done it myself but I’ll admit, I know just enough about electricity to be dangerous. I let the professionals handle it.
"Growing old is mandatory. Growing up is optional."
