Any troubleshooting help would be appreciated, as my electrical skills are weak.
2016 320 CS-S
AC power connected. Outlets work. Battery charged. All breakers on converter in on position.
Alde works fine on propane, but putting the slide switches (old style control panel) on electric heat does not generate cabin heat. Circulation pump runs though. Heating on propane works fine. AC aux fan works.
Fridge inside light turns on. No cooling at all though. No noise.
Thanks for any feedback.
How long have you waited to say Fridge is not working on 120VAC?
Very unlikely two different items would fail at same time . . . so issue has to be with Power Source or your observation of what is actually happening or not happening.
AC plug for Alde had wiggled loose. I’ll fire it up for a test, but 99% sure plugging it in will help. Haha. I do now recall reading that advice a while back, but I had forgotten.
The attached PDF file might be helpful - - - NR740 Service Manual
If the refrigerator is still out of the trailer you could take it to an HVAC shop in town. I bet they could fix it and not have to replace the whole thing. Line leaks can often (but not always) be resoldered.
