Planning on upgrading to either one or two Battleborn lithium batteries (100 - 200 Ah). I've heard that the solar charge controller in the 400 (ours is 2018 and has a "Rohs" brand controller) won't fully charge lithium batteries in the 400. Is this true? Should I invest in a new charge controller, such as a Victron?
Former T@B 400 owner, now thinking about a 320. 2019 Honda Ridgeline.
1 ·
The Victron charge controller can be set to whatever battery chemistry you have and in general I believe is a much better controller.
You also probably at least want to consider a converter or charger that is good for LiFePo4 too.
Anyway, beyond that I also made and installed 2/0 Gauge cabling between the 2 batteries and also to the main power junction block. Touched up the settings in the Solar Charge Controller and the BMV-712 battery monitor and I believe I am good to go. If I really decide to feel I am up for a challenge, I will move the gauge for the BMV-712 that is installed under the bed (I use the Bluetooth app on my phone) over by the Alde and AC controls. It's just a pain to remove the microwave and other stuff to get it done.
Anyway, here is a photo below to show the end result before putting the bed back on top of them.
Concord, NC
Sold 2023 Tab 400
Sold 2018 T@B 320S
Brad
Concord, NC
So, after I finished the installation and wring yesterday, I activated the Bulk Charging mode and my initial charge rate was 45 amps as per the BMV-712, voltage started around 13.5. Within 20 minutes the charge rate was nearly zero and the voltage was 14.4 indicating a full charge on the batteries. In the picture below you can see the PD9260CV and my shunt both.
Brad
I put the pendant so it was accessible from the outside rear compartment next to the display for the EMS-HW30C display as shown in the second picture.
Concord, NC
The PD was like $200.00 from Amazon with a remote pendant which is definitely the "preferred installation" to allow the "forced boost mode" which also allows this to work with Lithium.
You are correct, trying to charge the batteries with the WFCO in the location it is doesn't work well at all. This is not due to the WFCO not being capable, but more related to resistance in cables and wiring which causes the WFCO to bypass the Bulk Mode. @rh5555 detailed this very well previously, actually he done all of the time consuming work that allowed me the easy part of just installing the PD and short cables and removing the WFCO.
Brad
Concord, NC
So, when I installed the new converter and made the connections to the Junction Block, by default (accident), I actually had it correct so that I could see the improvement in charge rates since I could measure the amperage going into the batteries.
In the picture attached, I circled (poorly using a mouse) the factory installed cable that I moved from the Junction Block to the shunt.
Brad
Concord, NC
It's important to point out to others that are looking to upgrade their converter and have a BMV-712 that "it's not imperative that the current passes through the shunt unless you wish to see the improvement by being able to measure the Amps while charging" . The BMV-712 doesn't use the current passing through to reset the SOC (state of charge) back to 100%.
Here is a screenshot when I was at 94% and pressed the pendant to activate the "Boost Mode" which charges at 14.4 volts. You can see that it was pushing 55.8 amps into the batteries, it would have been higher but I had both vent fans running inside. At this rate, they can be nearly dead (180 to 190 amps drawn out) and it will charge to 100% in just over 3 hours.
Brad
Concord, NC
They are 3/8" and the batteries are 5/16". I bought 5/16" and drilled the 2 out for the 3/8" connection rather than buying a bag of each. 2/0 cable is expensive and so are the ends!
Brad
Concord, NC
@Dutch061 you are about to cost me some $$$
What I have found with 2 x Battleborn Lithium is that I still use way too many Ah, 50 to 60 per 24 hours. This is due to running 2 vent fans (I have a fantastic fan in the bathroom also) and the higher temps inside the camper forcing the refrigerator to run way more often. I believe that as the weather cools this fall that this will be much lower. The great news is that the Battleborn Lithium batteries are up to the task. I purposely really drew then down the last 2 days using 147 Amps before leaving for home, the voltage was still over 13 which is another great advantage of Lithium batteries, especially if you are going to use the inverter. Had I tried to use the inverter on the AGM after drawing 75% of the available Ah, I would have immediately gotten a low voltage alarm and the inverter would shut off. 2 1/2 hours after I plugged in at home they were at 100% SOC again.
So, although it has been an expensive ordeal, I am very satisfied with the end results.
If you are looking to only fix the charging aspect, that can be done easily for about $275.00. It takes about an hour to do this fix.
I spent another $2200.00 on 2 batteries, cable, terminals, and the tool to crimp them on the cables. I guess the good news is since this is our last RV, I hope to be able to use it for the next 10 years and shouldn't have to touch any of this stuff again.
Brad
Concord, NC
I chose Battleborn for 2 main reasons.
10 year warranty
Made in the greatest country in the world, the USA
In addition they (Battleborn) has done more testing and have people in house who know the answers to ANY questions you may have about upgrading. They are the benchmark that all other Lithium Battery Manufacturers or Dealers are trying to meet. At least if I were going to bring a battery to market, my goal would be to build a team and a product that would compare.
No, I have not been compensated to promote their products or have they asked me to. There are plenty of other testimonials regarding their products.
Brad
Concord, NC
In order for the cells in the batteries to balance, they need to reach a 100% State of Charge. Again, I can only speak to Battleborn with this statement.
The cost of the converter is minimal compared to the 2 batteries you have already purchased. In fact, it would cost way less to upgrade the converter than buying Solar Panels and a charge controller. But again, it depends on how you camp.
Brad
Concord, NC
Jeff & Amy
They can also install a SAE connection to your battery for a solar suitcase setup.
You just need to show them where the battery is under the bed. The WaCo converter is used on a lot of different RVs
Finally, do you think I should buy this stuff and then take it to the RV place, or ask them to buy it? I don’t know if I’m being smart or tacky by doing the purchasing.
