There are lots of great TV options out there and my intent is not to disparage anyone else's choices. After the safety aspect of towing, we all have our personal preferences. There are Fords, Toyotas, Hondas, etc that do a perfectly fine job. After driving Jeeps for over 30 years (aware the brand has changed ownership more than a few times..), I'm comfortable and really like the Dodge/Ram/Jeep style and interior setup. I've test driven nearly everything you can imagine lately, to research my options and I've settled on a 2019 or 2020 Ram 1500 5.7 Hemi Crew Cab 4x4 model. I tow in the mountains in Colorado, New Mexico, and Utah, hoping to get to Arizona soon. Although I try not to tow in big cities, or Intersate Highways, sometimes that option is the 'best'.
I saw mentions of Ram 1500s in other threads, but didn't want to hijack anyone's thread and wanted *specific* feedback regarding towing a 400 (Boondock or not) with a newer Ram 1500 V8. The model and options I'm considering has a rating of 11,470 pounds, factory setup. I know what my 400 BD axle rating is (3900 lbs), and don't plan to overload it or the tongue, but as a fulltimer, I'm feeling I need more TV capacity, in room and in safety margin. Again, just my preference, not disparaging anyone else's choices.
Funds are not unlimited, so before I go
too crazy with research, I'd like to hear actual experiences please. I respect the knowledge and willingness to help others on here, so I'm putting this request out there.
I have been towing my TaB409 with a Jeep Gladiator, similar rear ended suspension to a Ram 1500), with only the V6 Penstar engine and it works fine also, but you can feel the TaB load on steep hills. Just get the electric brake controller installed, and you should be good to go.
Towed by 2019 Ram 1500 Rebel 5.7L Hemi 4x4 Crew Cab
2021 T@B Boondock CS-S
2018 Nissan Pathfinder
Ontario, Canada
I've had only Jeeps for over 30 years, and know next to nothing about pickup trucks. Can anyone out there tell me how long my drawbar (ball mount?) needs to be please? I had a super long one (16") to clear the spare tire on the Wrangler, but purchased a shorter one for the Ram, 8" 8000lb rating, and the ball is rated for 6000lbs. I just don't want the tongue to hit the Truck bumber in a tight turn or backing. My drop is good, because I'm level fully loaded.
What length should I have?
(Pic below is with the 16" draw bar ball mount -too long)
The length of my drawbar (2019 F-150) was determined by how much space I needed for the tailgate to lie flat when opened. I ordered a 14 1/2” length drawbar, not an extender. My tailgate lays flat now.
I was concerned about this, and my hitch looked a little short, but it works. The shorter the truck connection the better (you increase the tongue weight when you extend the hitch point back from the truck). I took my setup, the JT and TaB400 over some narrow mountain roads in NorCal Hwy 1, no issues in the 180-degree switchbacks, the TaB just followed along behind.
I know already that the 16" drawbar I had (in the photo above) does not allow my tailgate to open flat - it hits the tongue jack. I'm uncomfortable going longer than that. No extenders, thanks to the knowledge shared on here.
If you go to a truck accessory shop, see if they can order a longer non-extension bar. Tillman’s in Greenwood, IN had to continue looking for about 5 minutes until he found that Curt did have the 14 1/2” bar. They really have to look through their computerized lists.
I'm getting ready to leave my campsite in the morning and tow for the first time with the 'short' 8" drawbar. I guess we'll know soon.
I'm the worst backer-upper in history, and had 'jack-knifed' the wrangler/400 once while backing. Luckily I had that 16" drawbar, so no real harm.
The Wrangler has a shot wheel base compared to a truck, so backing up movements are quicker, and tighter turns easier to make, sometimes too easy, so you end up over steering and loos control. The longer wheel base makes backing up straight easier, andbturn are more gradual and better controlled.
Good luck with your new rig.
Towing milage depends on the trailer and truck loading, along with the model you choose. A Rubicon or Sport S with Max Tow is going to have a lower final gear ratio, so will get less MPG. The speed you tow at will also make a difference, once you get over 65mph, milage drops even without a trailer.
I have a Sport S with regular tow package, so I get 18-20 mpg running around rural country roads over hill and dale as it were. On highway driving (Hwy 101) I get 24-26 mpg running at 60 to 65 mph, with occasional 70 mph on down grades.
Pulling the TaB400 I got 18-20 mpg on Hwy 101, and dropped to 1around an average of 14 to 16 mpg on the coast highway getting back to home, about the same I get towing a loaded utility trailer on the coast roads, at 35-50 mph (road conditions restrict speeds here). So milage is better than I got with my Dodge Dakota, with Max Tow, pulling similar trailers.
My WK2 Trailhawk is good compromise for me, unfortunately I dont love the look of it.
What does your Oil Temp run when towing please? Mine ran at 222dF and briefly 224 yesterday towing my T@B 400. About 76 degrees out, A/C on, tiny little hills at 60 mph highway (not stop and go). Do you think that's normal?
During the trip last year, I had to find a Ram dealer in South Dakota to do my oil change because I followed the recommended interval oil change at 10,000 miles by my dealer. I checked the manual, but if I remember correctly, it was not even listed. I had them put synthetic oil because I was anticipating uphill and downhill driving heading west and when I reached Utah’s national parks. Maybe, if a “light” or dashboard message came on, I would have noticed it.
Maybe another reader will be able to answer your question. On my next trip this month, I will check it out and play with the menu in the truck. Please check where you hook up your Tab’s “electric brake cable”. My dealer hooked it up with the chain that you attached to the truck and I did not even noticed it until I’ve traveled for almost a year. It should be hooked up to the truck separately and not attached to the chain.
Enjoy your truck and Tab 400. Happy camping.
I can feel the 320 more than the PUP, mainly with that big slab blocking air.
I keep it around 58 to 60, seems that's the best gas mileage which on the flat FL roads is around 15. When I was towing the PUP I got around 19 or 20 and without anything and on cruise at 58 I can get 21 to 24.
Tampa FL
I also put a trunk rubber mat on my truck bed so that my plastic bins will slide easily when I pull them out. I have 4 bins: One for electrical contents (surge protector, extension cords, etc), one for water-related items (hose, filter, pressure regulator, etc), one for picnic items (tablecloth, ropes, etc) and one for miscellaneous. I have a 4-foot stick with a hook on one end to pull out the bins.
For your ARB power supply in the trunk, please let us know if your dealer will install a 9 volt outlet wired directly to your truck battery. Tell them that it should have an in-line fuse and should be marine-grade (waterproof) outlet with USB slots.
Just a thought.
Most say 215 to 220 is normal and upwards to 225.
2 posts mentioned removing a shutter assembly which lowered all the temps, oil, cooling and tranny?
One said to run 5W20 synthetic oil, they said that's what their manual suggested.
Others suggested monitoring the oil life, and make sure no warning lights come on.
This was interesting
Given your location (Texas), 220F is pretty normal for daytime driving during the summer. 225F is not too high for the oil, assuming it is a modern SN rated conventional or synthetic oil.
For conventional oils, you do not want to it to see anything north of 275F, as its performance will quickly degrade after that. For synthetics, 300F is the point at which things will start going downhill in a hurry.
However, unless you are running the engine full-out for extended periods of time, its oil should not even approach 275F in temperature. So you can rest easy with the new truck.
Now, if you decide to hook up a trailer with another truck on it and then go try to maintain 65mph up one side of a mountain, you should definitely keep an eye on the oil temps
Tampa FL
The Dealer where I bought it won't have time to put in a power port before I leave, but with your info, I'll get it done on a longer stop.
I'm researching drawer-like pullout trays for my stuff. Right now it's all piled in the (very roomy, might I add) cab!
I kind of envy you with a shiny super duper truck, but with the way manufacturers have been going the last few years, it's a lot more fancy accessories/systems to break or act up (not that my 06 doesn't have it's share).
Tampa FL
But everything is controlled by computers. Even the intermittent turn signal. If you bump the turn signal it will flash 3 times and stop. It can be programmed with a software program (not part of the delivered vehicle) to flash more if you want.
PNW
