I’m ready to take my tab out for its maiden voyage this week. I filled the holding tank with some water at home just to make sure everything was working. I flushed just once and ran the sink for maybe 10 sec. just to practice I opened the gray water valve and water just kept coming and coming. Way more than I used.
When you say "maiden voyage" I assume you recently purchased your TAB? Did you winterize it or did the dealer just tell you it had been winterized. It is possible that the dealer ran water into the gray tank and overlooked draining it as part of the winterization process?
2022 Ford F350 Tremor | 2022 Cirrus 620
