Does anyone have any photos of how nuCamp (or others) attaches the spare tire to the front tub? I have a 320 S Boondock Lite with a Boondock spare and would like to know if a spare tire carrier can be mounted to the tub. Any part number info or other details for mounting a spare tire carrier in that location would be appreciated. I am looking for photos that show how and where they bolt the carrier, as well as how much clearance it leaves between the back side of the wheel and the front exterior of the tub. Thanks in advance!
2019 T@B 320 S Boondock Lite; 2025 Toyota Tundra CrewMax 4x4
(Alde: 3020; Refrig: Isotherm Cruise 65 Eleg; Battery: BB 100Ah LiFePo4; Solar: Renogy 100Ah Suitcase; Victron BMV-712; Pwr Cntr: PD-4135KW2B; EMS: PI-HW30C)
1 ·
I considered a functionally similar bracket available online for less than half the price, but I was worried about possible fatigue of the diamond-plate where it attached. I thought perhaps nuCamp's bracket would attach to the frame, but it also attaches to the bin (I was amazed that among all the videos online, NONE gave a good view of the attachment!)
Anyway, there it is, a robust aluminum part. Notice that the bracket mating plate for the bin is curved to the same radius of the diamond-plate, offering a tight attachment. There were no instructions included, but I mounted it such that the weight of the tire was borne entirely by the platform below, and the bracket provided only horizontal stability. nuCamp supplies the attachment hardware, but I bought a couple of large fender washers and plastic-insert lock nuts to help spread the forces away from the bolt holes. Here's a picture of the nuts and washers inside the bin:
Good luck!
I separately purchased stainless steel bolts to attach the carrier to the aluminum tub. It mounts with four bolts, which will be tightened against powder coated vertical brackets inside the tub. The Maxxhaul (which is rated to hold 100#) does not have the curved mounting base to match the curvature of the tub, which is definitely a nice feature of the nuCamp version.
It is evident that your carrier is specially designed for the Boondock tub, whereas the Maxxhaul carrier is designed to mount on a flat trailer frame. However, to compensate for that, I am going to add some rubber or neoprene spacers over the shaft of each bolt between the carrier mount and the tub to (a) fill the relatively small gap that results from a straight (rather than curved) mounting plate, and (b) to act as a buffer between the steel (albeit powder-coated) mounting plate and the aluminum tub.
Fortunately, as you have found, there is really no weight placed on the carrier in this configuration, because the spare tire rests on the Boondock platform and merely provides horizontal support. Therefore, I do not anticipate that the carrier will create any fatigue at the tub. It will likely be a couple weeks before I mount the spare tire carrier. Hopefully, I did not make a mistake going this route. I suppose I could change course and order the nuCamp carrier, but I'm not sure it makes a significant difference. Hopefully, all will go well.
After thinking about it overnight, however, I may purchase the aluminum carrier from nüCamp like @SolarSteve did. I really like how the mounting plate fits the curve of the tub. It is more expensive than the Maxxhaul, but it will provide a better fit and cleaner look. Also, after looking closer at the Maxxhaul carrier, the nüCamp version has a better/thicker weld. These positive aspects make it worth the $100 to me.
@SolarSteve, can you tell me which dealer you went through to make the purchase? Also, do you know what the approximate "off-set" measurement is between the two metal plates of your carrier? (The measurement I am interested in is 6" for the Maxxhaul, as depicted in the photo with the lower ruler.) Thanks!
Hi Bayless. I’ve been on the road and haven’t had a chance to respond to your other messages (I’m new to the forum).
My dealer is Windish RV in Lakewood CO. Price was $111 and they gave me a 10% discount because I bought my TAB there, so that came to $100. You wouldn’t get that discount. Then when I picked it up, they tacked on the shipping costs from nuCamp to them.
I measured the nuCamp bracket offset from one mounting face to the other. Six inches exactly, just like yours.
Regarding the Maxxhaul bracket you have already ordered, that’s the same one I considered. I bought the nuCamp bracket only because I wasn’t sure how it mounted and didn’t trust mounting it to the bin. But knowing what I know now, it seems a feasible alternative, especially since your bracket is strong enough to support the weight of the entire tire when clamped to the frame.
What I had envisioned was placing those two small vertical bars on the *outside* of the bin so that the flat mating surface of the bracket could bridge the curve of the bin. Then inside the bin I was going to use either fender washers or a steel backing plate bent to the curve of the bin.
It seems the only risk to going ahead with your bracket is the holes drilled in the bin. But even if it doesn’t work, you can go ahead and order the nuCamp.
Steve
just sayin
2019 320 Boondock Edge - Sold Jan 2022
Until seeing your photo of a break at the tire cage nut, I was only aware from the experience of another T@B owner that the cage had broke (at an unknown location.) My cage started to wear through due to my "Jack-It" bike rack tower rubbing against the tire cage. The metal of the cage had worn significantly, so it wasn't safe to use. The metal cage is actually worthy of a formal manufacturer's recall, because as @gulfarea notes, the Boondock tire becoming dislodged and jettisoned while travelling down the highway would be extremely dangerous.
Fortunately, as @SolarSteve noted above, the spare tire bracket essentially only provides horizontal stability for the spare, so it is not bearing any weight from the tire or pulling on the aluminum tub. Regardless, I do feel it makes sense to secure the tub to the aluminum frame more securely than the factory attachment (i.e., four small self-tapping screws.) In addition to that, I have always locked the spare to the trailer frame with a thick cable lock, not only to prevent theft, but also to keep the spare attached to the trailer in the event something caused it to become detached from its carrier/cage.
You can see this in a few dealer online sale ads, where the TaB has not been prepared for delivery yet. I agree, larger frame fasteners should be used.
Here's a photo of the aluminum insert/support installed inside the aluminum tub:
And, for anyone who is interested, here is a photo of the 1 1/4" self-tapping screw (three total) that is used to mount the aluminum tub to the Boondock's aluminum platform. They actually appear to hold the tub pretty well to the platform, because they are drilled into the aluminum tubing of the platform:
Huntington LI
I have never thought about it, but do you know if there is anything unique about the threads on a wheel lug? In other words, will I be able to find a standard stainless steel bolt with the same thread size to work with the black lug nuts that were included with the nüCamp carrier? Also, there is some sort of silver coating around the wheel lugs where they meet the mounting plate (see photo below.) I am not sure what that is, unless it is something similar to Loctite. Do you know what that is?
Thank you very much for the suggestion. I am now jealous, because my wife says you are her hero.
Huntington LI
https://www.mcmaster.com/
Huntington LI
I saw your tale of woe about the clearance of the tire around your bike mount. Another option would be to hammer the studs out and then drill their holes ever so slightly larger so the studs can be easily removed when the lug nuts are removed. When mounted, the lug nuts would hold the studs firmly in place.
Homydom Spare Tire Carrier, Spare Tire Bracket for Trailer, Mounts to Your Trailer Powder Coat Fits 4 & 5 & 6 Lugs Trailer Wheels on 4", 4.25", 4.5", 4.75", 5", 5.5" and 6" Bolt Patterns Black
