@mmontz, is what you are referring to is the gap between the trim (which is normal), or that glob of something (not normal)............that is what caught my attention. What is it?
Mine looks like that, too. If you look closely I believe you will find that the glob covers a screw head that appears to be holding the two pieces of trim together. I actually had to enlarge my glob as a small crack was radiating from the screw head. It's one of the things I inspect at the start of every season.
The glob isn't visible from the ground, so most of the time it's outta' sight, outta' mind! ;-)
Thanks everyone. It just did not fit with the rest of the workmanship on the trailer.
I agree, though I have found in general that whoever was running the caulking gun the day they built mine was definitely a little ham-fisted with the trigger... :-)
Sad to say that the re-occurring trim issue may prevent me upgrading to a 400 Boondock. Everything else on the 2015 T@B has been great. It's so annoying that it looks like it does.
The trim on the new 2021 T@b 320 should be the solution we have been hoping for. In addition to the technical changes, it looks awesome!
Chan - near Buffalo NY 2014 S Maxx 2011 Tacoma 4cyl ... edit: 2022 Tacoma 6cyl - oh yeah! A_Little_T@b'll_Do_Ya
hi folks, spoke to my dealer and he said they have never heard of this problem which probably goes to the earlier comment of "out of site, out of mind"...I believe, given that I live in a cold climate, water has frozen and caused the plastic trim to break away from the fastening screw. I've reached out to Nucamp but they told me to contact my dealer so not much help unfortunately. Any advice or guidance for a fix would be greatly appreciated. Thank you!
good news, Nucamp warranty division is shipping me replacement trim free of charge. Has anyone attempted replacing this trim personally rather than taking it to a dealer?
(Alde: 3020; Refrig: Isotherm Cruise 65 Eleg; Battery: BB 100Ah LiFePO4; Solar: Renogy 220W Portable Suitcase; Victron BMV-712; Pwr Cntr: PD-4135KW2B; EMS: PI-HW30C)
That gob of sealant is someone's attempt to glue it down.
Durango, CO
2015 S Outback
ScottG said:
