With the advent of the casette toilet, I am curious as to whether 2021 320 owners could get away without a refular sized sewer hose.
I have one of the caps on the grey tank that has a small cap that will fit a garden hose on my 2015 T@b. Could a 2021 owner get away with just a garden hose or would that be too painfully slow and start a riot at the dump station line?
Have read articles about Black Waste Macerator Pump systems draining into 3/4 inch hose. Owners 'pump-out' at full hook up sites or at home . . . . while reading a good book.
It is just a fancy 2-piece porta potty . . . .
When dumped into a standard toilet it is a Mess of smells and back smashes
Need to clean bathroom and take a shower after dumping.
How to Empty "technology" is not right - - - yet
And can connect the tote with a standard waste hose to dump station.
Knowing how US Business works, those stations will be $5/use and red blooded Americans will continue to dump in (free) public toilets leaving the mess for others to clean up.
Sorry, for being so negative, but difficult to see upside/positive when so many Americans seem to feel their person rights override community responsibility.
If the US RV Industry wants to go cassette then the US RV Industry should be educating/funding the installation of cassette dump stations!
In all of my travels I have never seen a bathroom wrecked by a casette toilet dumping run amuck. I have seen plenty of grossness at dump stations from blank tank dumping run amuck.
There are plenty of pay dump stations so I would have no issue with pay casette toilet machines.
We only now are moving from tenting to trailering. I've been told our 2021 320S Boondock is on the truck to us so I have no experience. As has been said above we expect to camp a lot in campgrounds with no dump stations so the cassette was thought a good option. But my question concerns the original graywater dump thread. I'm baffled probably by my naivety, as to why a short length of 3/4 inch hose isn't run into the woods and just let the water dump? Currently when tenting we throw our dirty clean up and dish water into the woods, and I assume people using outside showers don't capture the waste for dumping. I understand in developed grassy sites where just dumping wastewater may create mud or small ponds this is not acceptable but in the remoter campground sites we've been in I can't believe it's a problem. Unless a lot more waste water is generated trailering than tenting, I'll take the larger fresh water tank and what appears less plumbing under the sink for added storage. Our expectation are among others to use this trailer for staging on hiking/kayaking trips.
managed by VE Smart Network
At some spots, that is perfectly acceptable. It will be similar to tenting in that you will need to make sure you are not near water sources and that local laws will not be violated. Best to check with the local rangers.
Other considerations:
- Showers produce wastewater...probably a lot more than you would tenting.
- Both dishwater and showers could contain fragrances that attract unwanted critters
Tampa FL
On Past Life Boats used macerator between toilet bowl and holding tank which gave the microbes a headstart breaking down solids. Also made marine pump out (vacuum) less stressful.
One possible disadvantage of the RV set-up (macerator between tank and drain) for systems without a reliable back flush is you loose the extra suction / water volume to really flush out the holding tank . . . assuming one tops off the holding tank with fresh water prior to gravity dumping.
Tampa FL
