Hello all--wondering if anyone here has a Predator 2000 Watt "super quiet" inverter generator from Harbor Freight? Will it run your generator and/or a CPAP machine/nebulizer or instant pot or coffee pot?
Thanks for any info! I have a 2017 Tab 320S
2018 Tab 400
0 ·
*Look at this discussion about CPAP usage (using a 12VDC power cord for a CPAP is the best way to go IMO)
https://tab-rv.vanillacommunity.com/discussion/comment/137208#Comment_137208
* We are percolator pot over a gas fire folks, so can't help with coffee pot and instant pot question other than to say check the wattage on those appliances (Volts X Amps).
2019 320 Boondock Edge - Sold Jan 2022
But yes, absolutely should run the AC on your 2017 320 just fine where allowed.
A/C draws about 4.8 Amps max while running {~ 575 watts} with a compressor start-up surge in the 1,600 watt range.
Driveway testing {have not used in field} it ran the A/C just fine . . . engine noise does do go when compressor starts but does not stop generator.
Adventures: 58 Nights: 405 Towing Miles 50,180
2015 T@B M@X S White with Grey trim | TV 2021 Ascent Touring | Flagstaff AZ.
Concord, NC
You will have to prioritize what you need/want when you are camping and make choices based on your needs/ camping style... but I would encourage you to at least consider solar over a generator.
I don't think if you want to run AC any length of time that product will make you happy.
Can you run AC with LiFePo4 battery bank and solar? YES, but it is a huge system and probably $10k minimum. With a small trailer like a Tab, not enough roof real estate to mount the panels nor space to add a battery bank large enough. It could be done with the a full size pickup as tow vehicle and placing the batteries/power plant there and carrying maybe 2000w of portable panels, anything less is going to get you short run times for heavy loads like the AC.
300W solar and I see at least 220W+ most non-winter cloud free days and 18A+ solar charging. 330Ah non lithium batteries. Yes the A/C unit can peak as high as 600W, but that's rare... with the compressor on it's usually in the 400-500W range, and I also usually run it in Eco mode cycling on and off which can extend cooling from 3 hours of run time to up to 6 hours or more depending on the thermostat setting before the battery bank drops to 50%. And yup, it takes 10+ hours of solid sun to recharge it all the way to 100% with such a "small" system. So no, at this point I can't reliably have 4 hours of compressor-on air conditioning day after day after day. But T@bbers are known to kayak, bicycle, or do touristy things most of the day anyway, so we likely don't need 24h of A/C a day.
So my guess would be somewhere between the 300W and 2000W numbers, with a matching size battery bank. That's only for the 320 T@B. For a T@B 400 or larger all bets are off?
Mortons on the Move just went to a 2750W new solar setup on their 5th wheel. They run air conditioning and everything else with no worries. Ever. 5000W inverter, and I think it was 8 Battleborns.
We need somebody here with a T@B 400 to put on 900W of solar and 900Ah of Lithium and then sit in the Texas Hill Country for all of July or August and let us know if they can keep the camper at 80F or lower the whole time.
Maybe nüCamp will fund a 900W and 1200W experiment in preparation for the new T@B 540?
Yes they are as much or more than a generator, especially if you include their portable solar panels. But you are correct, the 3000 unit might only run the CoolCat AC for 2 to 4 hrs max compressor running time, so depending on its current draw after the compressor is running, and how long each compressor cycle is, you could get 4 to 6 hrs of run time, if the compressor cycles less frequently. The more cycles (very hot weather) the more the compressor runs, and more power required.
Yes it takes a full day to recharge, and I was thinking only using the AC at night to cool off before bed time.
see: https://www.goalzero.com/product-features/yeti-x/?utm_campaign=Yeti_X_Out_of_Stock&utm_content=touchpoint_1_message_a&utm_medium=email&utm_source=zaius
Honda EU2200i inverter generator
Hutch Mountain Propane Conversion Kit for Honda
Microair Easy Start Module
Hutch Mountain claims the East Start eliminates the need for a companion Honda to start and run a 13K-15K A/C unit.
One thing I do like about the conversion kit here is it does not eliminate the gas option. Most others I've found, so far, is an "either/or" scenario. If you install the kit, you lose the gas option.
@TNOutback
A very good point, made well. Thank you for enlightening the forum.
San Diego, CA
www.airbossone.com
Even though the single Honda 2200i does work, I am probably going to add the easy start, as it seems that will make the generator and compressor much happier.
I went with the Genconnex due to no regulator on generator, very clean factory look to the Genconnex conversion and may be one of the few if not only kits that has a warranty and is EPA approved. You do go to single fuel only (propane).
Thanks much. Good info. As much as I hate to drop $1700 on the Honda w/conversion and easy start it may be the direction to go. Runs what I need without needing to parallel a second genset and it's hard to argue with Honda quality.
San Diego, CA
www.airbossone.com
Watching this closely. I‘ve already invested in a gasoline 2250 kW unit, but if I could find a good price point on a propane-only, I would go that route, but it looks like the only way to get the higher kW capacities is via a duel-fuel unit. My Wen 2250 starts my Air8 with no problem.
Others have made the point, and I think it is a valid one, that the higher displacement of the Honda 2200kW unit gives it a leg-up on running through larger locked rotor/inrush current startups than the typical 79cc displacements, like my Wen generator.
San Diego, CA
www.airbossone.com
