It's my understanding that the stabilizers are not meant to be used for leveling the trailer. However, my spouse thinks they are. Right now the T@B is in our driveway with a little tilt to the west side. We got the No/So (front to back) leveled by cracking up the trailer wheel. But the E/W (side to side) is still off center. We cut some boards to put under the tires so I was thinking that's what we'd use to level it E/W. But they might be too thick and make us then off center to the east! Thoughts? Tips? Tricks? Thanks, K
2015 Tab S with Alde
0 ·
You do, however, want it to be close to level when using the trailer: #1 for simple comfort (e.g., while sleeping and while cooking something on the stove), and #2 so that your refrigerator and air conditioner operate properly and efficiently. It is important that the refrigerator be level, or close to level in both directions, to operate properly. Also, you did not indicate which year/model T@B you own, but if you have the Danby or similar air conditioner mounted on the upper driver side of the trailer, it is a good idea to have the trailer tongue cranked slightly downward at the front so that the condensation properly drains from the A/C unit.
(Alde: 3020; Refrig: Isotherm Cruise 65 Eleg; Battery: BB 100Ah LiFePO4; Solar: Renogy 220W Portable Suitcase; Victron BMV-712; Pwr Cntr: PD-4135KW2B; EMS: PI-HW30C)
Odessa, Fl.
I carry a bag of the Lego blocks just in case the stabilizers don't reach. Found them at Goodwill for $5.
Also have the Camco wheel dock that looks like a dog bowl that the nose wheel sits in.
Tampa FL
2017 Dodge Durango AWD with Tow Package IV
A can of Skyline Chili in the pantry
You and I along with the many installations that have been performed over the last 5 years. Have to my knowledge are all performing perfectly with no issues. That being said the pros and cons of this mod has been discussed many times. New comers to the T@B family would have to search back about 5 years to find detailed discussions as to why we are happy with it. All I can say is it has served us well, and I would do it again in a heartbeat.
