I looked at a brand new 2021 T@B 320S Boondock version today on a dealer lot.  The glass stove top cover will raise but hits the right side window molding before being upright enough to lock into position.  The glass has the proper notch cut out of the near-right corner as well. Neither the dealership sales person or I could get it to work even knowing the correct way to lift it up and let it drop down.  It simply bumps into the window trim that sticks out.
I noticed one other observation about this in the forums but no information about how it was fixed.  Has anyone had this corrected by NuCamp?
0 ·
Perhaps the stove top is shifted slightly to passenger side of counter cut-out for stove.
Might be possible to shift (and secure) toward driver side to allow glass corner notch to clear trim.
Ask 'sale person' to get a Service department guy to attempt adjusting.
original incorrect sized and correct replacement for future owner reference. {once new lid has arrived}
TV: 2021 BMW X5 Drive 40i
2020 Toyota Highlander
2021 T@B 320S Boondock | 2019 BMW X3 M40i
1) wrong glass top which will never stay up,
2) no glass top (since the correct one wasn't available at the time of shipment),
3) correct glass top that stays up.
I've included 2 pictures below of the new and correct glass top hinges. The first is the orientation that it would be in when closed, the second when it would be open. Note the difference in the distance from the hinge mounting plate (with screws) to the glass edge. When open and slid 'down', it is about 1/8" closer. If yours doesn't have this ability to slide closer, then no amount of adjustment will help. The hinges simply aren't the correct ones - that's my case. I'm presuming the supply shortage is coming to an end since I received my parts. While NuCamp originally suggested enlarging the hole in the countertop complete with instructions, I'm hoping no such enlargement is needed when one has the right top. Will provide an update once I've completed the installation.
A shot of the dimension from the wall and front edge:
Showing the lid up and the clearance to the window and side:
Oh yeah - DON'T drop the nuts or the little corner spacers on the counter / stove opening!
managed by VE Smart Network
I've found NüCamp very helpful, call with your stove to wall dimensions (reference mine if you want) but they can run out to the production floor and check but I bet they know of other ways it could be wrong. I'm glad the first top worked for us I worried about the heat and the window without it..
As far as the swap goes, breaking the silicone seal was easy, removing the old silicone was the toughest part. I padded the countertop well with old towels to avoid scratching anything - lots of sharp edges on the underside of the stovetop. It now sits up vertical with 1/2" to spare. I did not have to move the stovetop forward at all.
My hinges appear to match yours but it’s still hard to tell.
I do not see how the glass can be held upright by either one, so either I’m missing something obvious or these are just the wrong hinges, which seems like the right conclusion.
As far as your other question about which caulk to use, their PAP for the stove shows DAP Kwik Seal being used.
