Here is my Nucamp control panel with the battery button pushed. What is it telling me? Haven't plugged into shore power yet. Solar app says trailer battery is just fine. Why does this seem to say my battery is not fine?
The factory manual says only this about the Nucamp Control Panel:
"The nuCamp control panel is located near the main entrance door. On it you will find a tank fill level indicator, a battery charge level indicator and master switches to power lights and the water pump. Switch buttons will light up when activated."
That's it. The entire explanation of the famed nuCamp control panel.
I don't have solar so I do not know what the solar controllers tell you about the state of the battery. I installed a Victron battery monitor. I believe they can be used with a solar controller as well.
If you have solar, load the app to monitor battery health via Bluetooth on your phone.
San Diego, CA
www.airbossone.com
San Diego, CA
www.airbossone.com
Does your Solar App provide voltage values? If so use that information and the Current information and ignore the near useless KIB Panel.
Don't know which KIB PCB NüCamp is using. Several years ago I found this table on KIB voltages.
I hope @MuttonChops chart is not at all related to the current panel. 6 volts is far beyond "Low", it is a dead battery.
We don't have permanently installed solar so voltage can be an indicator, although not ideal, of battery charge status. Once we start camping again measuring voltage in comparison to the panel lights is a must do project for us. Has anyone else tried to do this?
Just asking if anyone knows.
The solar panel / controller is consistently applying power to the system to charge and operate equipment in the T@B. It is consistently noted here in the forum that all load and power to the battery must be removed for several hours before measuring voltage to determine battery charge status.
This is why so many install a battery monitor.
What does the Battery Voltage on the shown solar controller actually indicate?
Max. = Highest voltage seen in the system for the 24 hour period. (High Noon or converter running.)
Low = Lowest system voltage seen in the system for the 24 period. (At night with, in this case, no significant load.) Primarily the batter voltage.
On the second screen, instantaneous reading with little panel output and minor load.
@BywaysNW, assuming your converter, is not on if you can increase your 12vdc load and see what happens to the instantaneous voltage. I'm guessing it will drop.
It's ok, I'll weigh in anyway..
I agree with previous comments that the Smartsolar app's status screen showing battery voltage is equivalent to putting a voltmeter on the battery terminals. Whether or not you could infer the battery's current SOC from that depends on whether the solar is or has recently been charging it, and whether any significant loads (eg, >0.15A, say) have been disconnected for a while. If no charging or loads present for an hour or more, say, then you could probably infer an approximate state of charge, by comparison to the battery manufacturer's spec sheet.
If @BywaysNW had shown the status screenshot from the Smartsolar app at the 8:49pm time, if the panel had been dark already & loads were switched off, then that could have been useful info from which to validate the KIB lights maybe.
I'm glad we've had the old SeeLevel with voltage reading (limited to tenths though), even though it's now surpassed by a Victron BMV Monitor for accuracy. Still, it's good to have a backup. For comparison testing this morning, I unplugged the AC converter/charger, waited an hour, then checked the battery directly with a Fluke 115 voltmeter and got 12.68V with loads off except the CO2/propane detector, SeeLevel & USB (<0.1A total). Here's what the two built-in meters showed..
Our Trojan 1275 lead-acid golf cart battery (150AH) specs list 12.73V as 100% with open circuit (ours was not open, but in minimal use), and 12.62 as 90%.
managed by VE Smart Network
In general I believe if the KIB says Fair your battery is very near 50% SOC.
The last time I "got into" a KIB Panel was 10-years ago. The KIB battery voltage monitor was a very basic HARDWARE {semi-technical follows} arrangement of a reference voltage fed into a voltage divider with voltage comparitors 'comparing' the battery line voltage to each voltage divider step. There were no adjustments to the system . . . you get what you get based on PCB quality, individual OPAMP (comparitor) quality. And as I recall all parts were consumer grade, not industrial grade -- i.e. cheap
For someone that wants/needs to rely on the factory KIB Panel suggest they calibrate to actual battery voltage** under as low a load as possible.
Turn off everything, ideally use a variable VDC supply in place of battery, define when Your Panel switches from four to three LED on . . . not something the typical owner will or can do. One could also drain the battery, then turn off everything and use a voltmeter to measure battery. Either way, it takes some effort and time.
Side Note:
My SeeLevel reads about 0.2 volts higher then the Alde Service Screen Voltage. My Alde also will work when the Service Screen reads 12.0 volts (it cycles the propane on/off - - - lights burner for a few seconds then turns off - - - repeat). However the manual says gas shutdown is at 10.5 volts but not on mine . . . so at least my unit needs a battery well above KIB 'Fair' to operate.
Excellent solution!
I was trained as a Mfg Engineer.
Will try to keep future comments "basic"
And please ignore my grammar, spelling, etc 🙂
thoughts on this: install a cig lighter socket on the tank monitoring display and plug (or kludge permanent) a simple 12V monitor into it but only power it when the unused old black tank button is pressed? As stock the only other one is hidden in the undersink cabinet which is very tough to see. Putting it by the converter is better but I'm afraid of kicking it and it's also hard to see.
