Hello,
My grey water flange valve has four screws, one for each corner. One corner has cracked, as though the screw was too tight. Now it leaks. If I open the end cap, and leave the grey drain valve closed, no water comes out. So I am blaming the cracked flange valve in front of the drain valve. How do I replace it, and what do I replace it with? This flange is glued onto the pipe! If I saw it off, then the pipe will be too short. Do I have to replace the pipe? Help please!
2014 Little Guy T@B S Max
0 ·
The corner of the flange where it is screwed in to the other flange is cracked. I'm not sure this picture will help any. I tried to seal the crack with Marine Sealant, but just made a mess and it makes no difference; still leaking.... Under my camper is a real mess! I never noticed that...
I am guessing that it is the back side of where the gray water valve (and pull handle) connects to the gray water pipe. If so, then it is either a matter or replacing the valve assembly, OR cutting the pipe behind the valve and replacing it from that point. It shouldn't be too complicated, but it probably would be best for you to have it done by a dealer if you have never done anything like that.
This will give you an idea of what I am referring to. The only question is whether it is the valve, or a cracked pipe:
https://www.doityourselfrv.com/repair-bad-rv-waste-dump-gate-valve/
Here's a Valterra video that describes how the waste valve attaches and operates:
https://www.youtube.com/watch?v=jZhxPtqWhVk
