i have a 2016 T@B 320 CS-S. While dry camping water drains out of the relief valve (where the yellow valve is) a few seconds after running water. This occurs whether running either hot or cold water. The yellow relief valve is in the "off" position (down). Water flows through the faucet normally. Is there an adjustment on the water pump? Could it be the water pump has a filter and needs to be cleaned? Or could it be the water temp is too high?
(I updated the title for search purposes.)
0 ·
I would suggest emailing Tech@nucamprv.com and ask if it is necessary to change the valve and inquire about the pump pressure setting. I think someone on the forum adjusted their pump.
Please update us with what you end up doing.
You can cut the old rings off but need the tool to tighten the rings on the new connection.
