Securing / Parking / Chocking 320 S on Inclined Home Driveway
kvr99kvr99 Member Posts: 5
Hi - new T@B owner here.   Just brought my lovely 320 S home, seems I overlooked a little something ... I have no idea how to ensure my Tab doesn't roll right out of my driveway and into the street!  Driveway is inclined maybe 10-15 degrees.   Will good quality polyurethane chocks (like these https://www.etrailer.com/p-288-02011-2.html) do the trick?  I'd be nervous!   I thought about adding a Trimax "lock and chock" but not sure that will do it either.  If the asphalt is slick with rain, I'd be especially worried.   What do folks do in this kind of situation?  Many thanks!
Kurt
2019 T@B 320 S Boondock Edge, 2008 Toyota Highlander Hybrid
Ottawa, Canada
    @kvr99, welcome and congratulations on your trailer.  Something that provides friction between itself and your driveway is the answer. Off-hand, a house brick or paver would work. Others may have more pertinent suggestions. But, what a wonderful problem to solve. If you didn't have your t@b, this wouldn't be a concern. Enjoy your dilemma. It's all part of the adventure. Happy t@bbing!
  • MouseketabMouseketab Member Posts: 1,238
    A Bal Leveler around one of the tires would do very well, then chocks front and back of the other one. https://www.amazon.com/BAL-28050-Light-Trailer-Leveler/dp/B000BH5MAA
    Carol
    MOUSE-KE-T@B
    2022 nuCamp T@B 320 CS-S
    Harvest, AL
    edited June 2020
    Also at 10-15%.  In addition to chocks and stabilizers, I also use a tow strap from the rear spare tire support to a stable attachment point in the garage.  I could see a strong wind blast from a storm pushing it off chocks only, and having it deliver itself into my neighbor's living room across the street, for which they might not be grateful.
  • tabiphiletabiphile Member Posts: 468
    This would make a great little problem for a high school physics class.
    Poly chocks will not provide adequate friction on an inclined paved (a presumably sealed) asphalt driveway. The bal leveler also does not seem like a good idea. Whatever you decide to use, what you are looking for is good friction on both wheels. Lifting one wheel a bit is unloading that wheel and overloading the opposite one. You want both wheels to share the load equally. So.... use rubberized chocks in lieu of poly.
    Once you are chocked and decoupled lower the trailer tongue as far as you can to reduce the moment and decrease the force on the tires. Make sure that both wheels share the load.
    You could use a wheel lock to keep the wheels from being able to turn. You still need to think about it sliding. Rain won't matter since the patch under the tires will stay dry.
    Don't rely on the trailer brakes since they won't hold after the battery drains.
    Here is a style of rubberized chock to consider.   https://www.uline.com/Product/Detail/H-4193/Dock-and-Trailer-Equipment/Rubber-Wheel-Chocks-with-Handles-4-1-2-x-10-1-2-x-7?pricode=WA9682&gadtype=pla&id=H-4193&gclid=EAIaIQobChMI0OSd7_iX6gIVAYbICh32HQFHEAQYAyABEgKujfD_BwE&gclsrc=aw.ds
    You will find other chocks available at Tractor Supply.
    harbor Freight has rubber chocks.  The plastic will slide on a slick hard surface. Could you drill a hole thru the surface big enough to drop the front jack without the wheel into?
    Tampa FL
    I second the Harbor Freight rubber chocks.  They are not very expensive.  If you find them on sale, or with one of their coupons they are cheaper still.
    I would also consider chaining it to something anchored into the ground - like concrete😀. Not only will it not roll downhill when someone pulls the chocks, but it will give you some added security.
  • kvr99kvr99 Member Posts: 5
    What an awesome user community!  Thank-you all for your suggestions.   I will be experimenting in the next week or so, and will almost certainly do the double-safe thing, with rubberized chocks on each wheel, and also anchor straps/chains secured to brick wall beside garage.   I'll let you know if my trailer is still in my driveway, or in my neighbor's living room.  Should be one or the other.   Cheers!
    Kurt
    Ottawa, Canada
    I found the plastic chocks would not hold my 400 securely on a slope. +3 for the black rubber Harbor Freight Chocks. They do not slide and hold the 400 securely. I always use two per tire and I have a light duty nylon rope tied between them so I never leave one at a campground. I also replaced my tongue jack tire with a foot to help prevent inadvertent rolling.
    I agree with previous suggestions to remove the jockey wheel from the tongue jack and deploy all four stabilizers securely once parked. That's five non-rolling points to help keep the trailer planted!
  • ADRawliADRawli Member Posts: 199
    @kvr99. I think I’d be very cautious about thinking a brick wall to be a good anchor point, as well.  If you‘ve ever actually seen how brick walls are made on homes, in that they kind of ‘float’ in front of the plywood wall covering the home, then you’d probably understand what I mean.  They provide more support vertically (the weight of the wall itself up and down) than security of movement horizontally (i.e. pulling on an eye bolt screwed into a brick wall).   That type of force is probably not nearly as strong and secure as you might think.  I think you’d do better anchoring to the concrete of the driveway itself or some other securely anchored point of the frame of the home.  Anyway, just my two cents worth. It is definitively one to be cautious on.
    Alan & Natalie       McKinney, TX
    nüCamp:  2019 T@B 400 Boondock Lite
  • BrianZBrianZ Member Posts: 1,768
    edited June 2020
    Agree with @DougH & @ADRawli, otherwise it's a no go.
    Here's an example with the physics calculated, showing that a car parked in the rain on the 31-degree slope of a racetrack slope will slide down it (see example 5)..
    http://faculty.mansfield.edu/hiseri/MA1135/1135L15.pdf
    I've used the same coefficient of friction with a T@B weight of 2000 lbs at slopes between 10-15 degrees..
    12° and 15° are a "no-go", as the downhill weight exceeds the weight required to overcome the friction of tires on pavement.  At 10°, the downhill weight is 348 lbs, but it would take more than 395 lbs to make it slide.  Still that's only a 45 lb margin.  At 11° of slope, it's even more iffy, as it would only take 11 lbs more of a push to start it sliding.  And this is based on locked wheels (like if you pulled the pin on the safety brake).  I expect a plastic chock to have even less friction than a rubber one might have.
    Good for you, @kvr99, for asking the right question!
    Apologies to those who hate trigonometry, but the math tells us this is a very risky situation, short of maybe attaching the Tab to a steel cable anchored in concrete.  Even then, I'm imagining that hitching & unhitching could be another difficult situation, not to mention the stress on hitch & TV components after repeatedly backing up on such an incline.  Is there even a suitable anchor point for a cable at the rear of the Tab?
    I wonder what the steeper grades are on mountain roads.  I seem to recall seeing warning signs for some.  Maybe 9%?
    Also, great idea by @Tampakayaker - dropping the jack post into a concrete hole would provide an added safety margin, though you'd need to keep an eye on its attachment bolts to the frame for any signs of stress.
    Update:  I have not verified the true coefficient of friction value asserted in the above example of car tires on wet asphalt, or whether that is really a static friction value as opposed to a dynamic one.  The following list of coefficient values for various materials lists a value of 0.72 for car tires on dry asphalt, for example, which would yield a much different result..
    www.engineeringtoolbox.com/amp/friction-coefficients-d_778.html
    It's also apparent that various combinations of different (and even similar) materials can vary widely in their combined friction coefficients, and also depending on conditions such as wet/dry, rough/smooth, etc.  The only way to get a reliable coefficient value would be to test the actual materials by measuring how many pounds of force it would take to push the object (eg, a chocked T@B) on a similar but level surface (driveway), expressed as a fraction of its weight, then repeat the calculations above.
    How about putting a post in the ground with a 2 inch ball!
    Ooooh.... I like that idea, but you’d still have to work out the logistics of how to get the hitch off the TV’s ball and onto the post’s ball without moving the trailer (which would be especially scary on a steep slope).  The idea of parking on slope that steep just seems to have many ‘watch outs’ no matter the solution.  It really depends on the true angle of the slope I guess.  <10% with quality chocks may be fine... but ~15%... yikes!   In lieu of a solid anchor point on both ends of any anchoring chain/strap, I think I’d be looking for another parking option.
    @kvr99 Looking at the @BrianZ calculations and the comment above from @ADRawli, this is a situation where accurate data is key. You need to measure that angle to determine just how safe it would be. There are smartphone apps available where you can literally open the app and lay the phone on the driveway to figure this out. This is how I found my own problematic driveway is 12% in one section nearest the curb, but 6% nearer the top and almost flat in the carport where both trailer and vehicle are parked, which was key info when I was looking at motorized trailer dollies—most can’t handle that 12% grade.
    Keep in mind too, if you have a 3-way fridge, even a 6% grade is too steep to run it, so you won’t be able to prechill the fridge the night before leaving on a trip. (Non issue if your fridge is not a 3-way.)
  • kduckkduck Member Posts: 1
    I have a 2018 320 CS-S parked on my driveway with an 8-10 degree slope (per an iphone app). I have the BAL leveler on one side (mostly correcting the 2.9 degree slope side to side) and a BAL locking chock on the other side. My driveway is concrete and we are in rainy oregon. Its been parked this way for about 6 weeks and I’m confident in the setup so far. The trailer does do an alarming little scoot when we pull it off the hitch, I think just on the locking chock side (the leveler side doesn’t seem to move at all) but it stops quickly.
    I’d like to be able to store my trailer like this long term but if It’s bad for the trailer or possibly not as secure as it seems I’d love input on that. The wish I could understand the physics calculations but my brain goes to static when I try.
    Our driveway slopes down toward our house so if my system fails it will damage the trailer and my house, but would not go rolling wild in the street or threaten anything or anyone in my neighborhood.
    I have a tab 400 boon dock with a sloped driveway. I use the red poly curved levelling ride up wedge on one side to level it. Then the poly wedges on both wheels. The jack has had the wheel removed with a flat foot since about a week after i had it.
    My drive is old blacktop. The trailer does not move when parked rain or snow.
    I assume the blacktop being a bit rough helps the poly wedges grip. They do come with rubber mats, but ive never needed to use them. i also wind the trailer jockey up until the tab is level.
    I give the whole thing a good tug from the side with the TV very close to test, but has never moved.
    This article has an incredible photo of a jacked up trailer on a very steep driveway..  While I can see how they might have accomplished it, it's hard to imagine how that could possibly be safe.  It may even be photoshopped.  Pretty scary looking.
    https://rvblogger.com/blog/how-to-level-travel-trailer-slope/
    edited June 2020
    Lol.   I think that was a deleted scene from "Jack@ss - The Movie".   The next clip three guys lie on their backs under it drinking shooters.
    Kurt
    Ottawa, Canada
    This is an interesting thread.  I too have a steep (asphalt) driveway (no idea what the angle is), but mine slopes toward my house.  There is a bit of a side extension of the driveway next to my garage, and that is where I am parking my T@B, it isn't as steep as the driveway, but it isn't nearly level and, like @kduck, I did have the trailer do a bit of a "scoot" once when I disconnected it from the hitch.  I usually use my Anderson levelers when I park it and chock both wheels, plus putting down the stabilizers, and, of course the tongue support -- figuring the more points of contact I have the better.  But I am still a bit nervous.  The last time I parked the T@B, I opted to forgo the Anderson levelers and leave the tires in full contact with the asphalt and just chocked them.  I really have no idea which is the safer way to go with this.
    I have wondered about having some sort of curb installed at the end of the asphalt as an additional safety measure, but haven't checked into that yet.  I think I'll look into those heavy duty chocks, even the rubber ones I have seem rather small for the job.
