Ok, I have looked on previous posts but a little confused. I want to connect my iPhone to my Jensen Tv. WiFi hotspot ? HDMI cable, some apple product ? Magic ?
I just want to be able (when I have a cell signal of course) to stream from my phone to the TV.
2019 320S Boondock Edge
0 ·
2019 320 Boondock Edge - Sold Jan 2022
San Diego, CA
www.airbossone.com
https://teardrop-trailers.vanillacommunity.com/discussion/908/installing-a-desktop-computer-in-a-t-g
WilliamA
2017 T@G XL
It's the (something or other, something or other) 730L cellular modem. I got this one from Verizon along with a data plan. It's a USB modem so therefore, doesn't need a battery or separate power source like a hotspot (I've also got one of those) as it simply plugs into your computer with a usb cable. It doesn't need any software/apps to work and, from my own experience anyway, simply gets recognized and goes to work. It gets fantastic reception where my celphone won't and best of all, has a port for using an external antenna. For an external antenna, I used the one that can be bought as an accessory for this modem. It's a mag-mount that seems to get fantastic reception. Here in my yard in the hollow where I get no celphone reception at all, I can get enough through this setup to surf the internet. Not enough for youtube/streaming movies, but keep in mind that on my celphone here I can't get enough signal to check my email, let alone surf the net.
The external antenna (a good one) is the key to getting the most out of available signal. There's no getting around it. I've had it with finicky, battery powered hotspots that you can either plug in for signal or plug in to charge, but not both. That's a BS device.
What you plug it into is another matter. I've tried laptops and they have the same problems that the hotspot modems have: i.e. no way to functionally charge them while you use them off the grid, dozens of cables and adapters to make them work, a small keyboard etc. Once you hook up a laptop, you still have the managements problems of "casting" the video from the laptop up to the Jensen TV and then trying to get the audio signal out to the Jensen radio. More cables, plugs, wires.
It can be done. I've done it a dozen ways now and feel that at last, I've staggered, stumbled into the most streamlined way to do it yet. That's in my thread (the link above) over on the T@G forum.
WilliamA
2017 T@G XL
San Diego, CA
www.airbossone.com
Are you trying to live stream from those services, or have you downloaded content to your phone then connect to the TV?
I would go thru your phone and turn off everything you don't need to have on for getting the material and sending it to the TV.
Tampa FL
I agree the wireless won't cut it. I believe you need to have a WiFi network set up for most of them to work (Apple TV, Chromecast, etc).
I don't have a 'top of the' line Android but the wired connection won't work with it either.
We have been looking at a SurfaceGo (Microsoft's tablet). A new version is due out in the coming month's. I think it has the video driver capability needed and is tablet sized. Will ask the person at the store for a demo before I plunk down the plastic though.
Good luck in the quest. Let us know if you find a solution!
I'm guessing that you realize that unlike the Jensen the LG TV won't run off 12v (battery) power.
As far as mirroring your iPhone to the TV, in some cases (Netflix for example) you have to be using the actual Apple Lighting-HDMI adapter (not a knock-off) AND have the adapter plugged into a power source in order for the adapter to work properly. My understanding is that there is some kind of chip in the Apple adapter that handles DRM.
CHOETECH USB C to HDMI Adapter (4K@60Hz), Type C to HDMI Adapter Cable Thunderbolt 3 Compatible with MacBook Pro/iPad Pro/ MacBook Air 2018, iMac 2017, Surface Book 2, Samsung Galaxy Note 9/S9/Note 8 https://www.amazon.com/dp/B071DGKBYP/ref=cm_sw_r_cp_apa_i_X2czEbQB9GHC9
I keep a lot of files on my phone's micro-SD storage card, and I'm currently in the process, as I write this, of upgrading to a 512GB card, since my 256GB card is 90% full. Six years worth of photos from multiple phones (Note3, Note4 & Note7 previously) take up most of the space, but also videos & document files. We have watched movies this way on the T@B TV.
@Marceline, I think @BrianZ was responding to my later comment about Android phones.
So great to be able to pool knowledge and ideas here...
I connect a Miracast dongle to the TV and stream from my phone, wirelessly. I use the Microsoft wireless display adapter.
We Tabbers can agree to disagree.
I usually download a TV series before I travel.
It's nice to have options though.
iPhone technology may not be up to par with Android in this category, though .
As for the Lightning adapter, if it didn't come in Apple packaging with a $50 price tag it's probably not a genuine Apple adapter.
