Definitely never get that cold. And after this weekend, I added fridge thermometer to my T@B packing list. I want to be sure I don't kill myself with Chicken or Mayo!MuttonChops said:Yes, condensation is normal. I use bins on bottom shelf to keep items from moving while traveling and they collect some of it, every few days dump out bin water and wipe-up bottom shelf.Suggest you purchase a small battery powered Fridge thermometer so you can monitor temperature. I frequently turn Fridge off at night to prevent freezing - - dislike ice in my morning cereal with milk.
You are a craftsman! I'm definitely using your solution as my squishy bucket is not ideal.Dalehelman said:This is how we handle frig. Condensation. If you in an area of hi humidity you will experience more water collection. We use a paper towel to absorb and control it. I cut the tray from a plastic cutlery tray from Walmart.
With this drip tray water never gets to the bottom. We also put small items in it like yogurt. The water drips directly off of the aluminum fins above so everything else stays dry.Dalehelman said:This is how we handle frig. Condensation. If you in an area of hi humidity you will experience more water collection. We use a paper towel to absorb and control it. I cut the tray from a plastic cutlery tray from Walmart.
How full was your fridge? I noticed it seemed to stay cooler the fuller the fridge was.KellyG said:Definitely never get that cold. And after this weekend, I added fridge thermometer to my T@B packing list. I want to be sure I don't kill myself with Chicken or Mayo!MuttonChops said:Yes, condensation is normal. I use bins on bottom shelf to keep items from moving while traveling and they collect some of it, every few days dump out bin water and wipe-up bottom shelf.Suggest you purchase a small battery powered Fridge thermometer so you can monitor temperature. I frequently turn Fridge off at night to prevent freezing - - dislike ice in my morning cereal with milk.
Unfortunately, I keep my T@B at a permanent site about 40 minutes from my house so I don't turn on the fridge till I get there. This time, I began cooling it at about 1:30 pm on a Saturday at 90 degrees and the coldest it got 8 hours later was about 55-60 degrees with some cooler inserts in it. After 24 hours, it had made it down to 45 degrees. For weekends, the fridge really isn't safe for most things. I bought a good cooler to try to help with that.ChanW said:Are you pre-cooling the fridge before your trips? 12 hours or so helps
