Newbie here looking at possible small trailers that we can tow with out existing vehicle. A factory tow fitted Jeep Cherokee. Rated for 4500lbs towing, 450 hitch weight, & 1000lb payload.
Reckon we're will be on our limits for payload and hitch weight. Our payload will be maxed out with hitch, passengers, and a WDH.
The latest 400 BD is showing as 372lb wet hitch weight?
Any folks here know their loaded trailer and hitch weights are on the latest 400 Boondock? I know there is at least one user here towing a 400 with a Jeep Cherokee. How much can I lighten the hitch by moving/securing the propane to the rear of the trailer, does a full fresh water tank shift the weight backwards? And of course I'm mindful of maintaining the min 10% load on the hitch.
Thanks for any help..
0 ·
Also, “wet weight” doesn’t include your gear. You will almost always run a higher tongue weight than shown. And at least some 2021 models currently on lots have moved the AC up front again, which may put them back into a heavier tongue weight than listed. The 2020 was tongue-light due to moving the AC under the bed and a lighter AC unit that was a poor design choice they appear to be correcting.
As someone who runs right up to their tongue weight limit currently and hasn’t in the past with other vehicle/trailer combos, I have to say I strongly don’t recommend it. Getting the trailer ready to go is WAY easier when you aren’t weighing the tongue, shifting stuff around, weighing again, shifting stuff around again. You have to carry less overall than your fellow owners, can’t just add things like second propane tanks (or second batteries on the 320), can’t carry the spare tire up front, shouldn’t load as much into the cargo area of the car because it’s still behind the car axle, and it’s all around a more stressful experience. I’m looking forward to the day I can afford to switch tow vehicles, hopefully sometime this year.
AC is up front.
The axle moved forward and helped a lot with tongue weight.
Water tank was 2/3 full. Not sure but it seems the center of the water tank is just rear of axle.
However both waste tanks are forward of axle so tongue weight will certainly be affected by waste tanks.
We do not have a Boondock, but we do have aluminum front box and platform. I wanted a Boondock but the standard trailer fit in our garage by literally 1/4"
Much of the storage is behind axle including the fridge. I think if you try just a little bit and put your heavy items in the back the "loaded" tongue weight should not change enough to matter.
With the exception of the waste tanks (1/2 filled they weigh 125lbs).
I took a picture with a rope in the location of the axle to show which cabinets are behind axle.
Yes we took the bathroom door out, my first mod.
https://podcasts.google.com/?feed=aHR0cHM6Ly9mZWVkLnBvZGJlYW4uY29tL3J2c21hbGx0YWxrL2ZlZWQueG1s&episode=cnZzbWFsbHRhbGsucG9kYmVhbi5jb20vMzk3NzU5NWUtYWIxYS01OGY0LWE3NzEtZjMyNzFiMjQzNjcy
It's a pretty interesting listen. PJ knows her stuff.
At least NüCamp has a 'wet' tongue weight ( propane tank full & battery ? ).
Really believe the rule-of-thumb that trailer GVW should be 75% or less of TV rating to take this marketing b.s. into account should be followed. Highly recommend everyone to purchase TV with a tongue weight rating and maximum towing capacity as much above the advertised trailer 'dry weigh' as budget allows.
Having extra capacity is never an issue, being at or below capacity can be a reallll pain
. . . I know been there . . .
Hadn't realized how long that truck is.
I watch "The Fast Lane Truck" YouTube channel, and they only got 8.5 mpg with the Gladiator on a flat mpg run towing 4,300lbs.
https://www.youtube.com/watch?v=TrLPpBWRxSI
next they were using a Rubicon, with a lower rear end gear ratio,
and third they were going 65-70 mph, towing a lot of drag area from both the trailer and the Jeep Gladiator.
So not surprised by the poor mileage. I would have gotten about the same with a similar setup (5500 lbs tow package, with a low rear end gear) Dakota.
I have a Gladiator Sport, with a higher rear gear ratio, a little lower trailer profile, and was only going 55-60 mph max, half the trip over the mountains was at 40-45 mph. So my wind drag was a lot less, my engine rpms lower, and got better gas mileage. Also, my TaB400 was empty, so my load was Less than 3,000 lbs.
The 18-20mpg was on the highway part of the trip.
Those TFL guys are usually doing their tests on I-70 @11,000 feet, somewhere east of Veil, CO. Aka, they’re REALLY high up and doing some of the toughest stretches of the interstates that I’ve ever driven.
I’d agree that 20 mpg is spectacular for towing anything.
2019 Toyota Tacoma TRD Off-Road
Seattle, WA
And the trailer they pull is a 4,300lbs 15ft box V-nose horse trailer with a tongue to bumper length of 18 ft, and is 7 ft wide - and overall height is a little lower than the T@B. Don't know the actual numbers but the frontal area is going to be very similar to a T@B400. It is surprisingly similar dimensions to the T@B, except 1,000lbs heavier.
You're referencing the "Ike Gauntlet", which is over the continental divide through the Eisenhower Tunnel, but that's a completely different towing test.
And I love old Healeys - wonder how that would pull!!
