I just made a call to the factory to confirm a couple of details that I couldn't find online, and they said that they have now switched over to installing Victron Solar Charge Controllers for 400's with factory solar installed. It sounds like with their smartphone app, this may now obviate the need to install the (popular) 700/712 battery monitors, which indeed seem a bit expensive for what they are, even though it is information we should have readily available when off the grid.
Just thought I'd share, as I hadn't seen this posted anywhere (don't quite me on it!)
-Jeff
The reason is that the solar controller doesn’t actually provide the state of charge, nor time left to full discharge (50%) based on current use. While the controller does provide the current battery charge voltage and you can surmise the SOC, it’s an approximation only. For $200, which I agree ain’t cheap, it gives me peace of mind knowing a more exact state of the expensive AGM batteries and seems worth it to me.
I have no clue how to do this so hopefully I won’t blow anything up. Lol
Thanks for the input!
YES! They started using that mid 2019 builds.
table mod
Towed by 2019 Ram 1500 Rebel 5.7L Hemi 4x4 Crew Cab
@TNOutback
Curious how you thought the installation of the BMC712 went. Where did you locate the monitor? Much wood butchering required. Running wiring fairly straight-forward? Is it worth seeking professional installation?
I'm no electrician but I have a moderate level of knowledge in wiring 200amp electrical panels and installing fixtures in a home and barn some years past (at least it passed inspection!).
Thanks in advance.
San Diego, CA
www.airbossone.com
The battery shunt in mine is mounted on the rear wall of the Air8 compartment, which is where I would have put it myself. Just need a short length of battery cable to run from it to the distribution block mounted on the floor there.
Think it would be a good project for you.
@Denny16
Do have the app and it works really well.
You guys are awesome. Thanks much.
San Diego, CA
www.airbossone.com
Watched nicely done YouTube video by "Grefe Away" installing BMV-712 in 2020 T@B 400. They simply used a ziptie to hold monitor and gathered wire to cables under the bed panel. The app is way easier to deal with and provides more information at-a-glance. Bluetooth works seamlessly with both Victron apps. We did same as Grefe Away. If we gently raise the under-bed access panel, the monitor is there for reading.
https://www.victronenergy.com/live/victronconnect:ve-smart-networking
