This discussion was created from comments split from:
Alde removal.
I split this topic as it diverged into a discussion of condensation in the T@B, which folk many find valuable on its own.
Sterling, VA
Great idea Mouseket@b! Have to check that one out...
I still don't quite understand how the sealed circulation Alde could add moisture to the air. If heating the air would do it, I would think the space heater would also.
For the Alde system on my T@bitha, I've yet to test out something I just installed. Facing the reclining backseat, under the left side seat bench where the heat comes out of the back fins, I installed a usb fan that has on and off switch (http://www.amazon.com/gp/product/B0065O6HFC?psc=1&redirect=true&ref_=oh_aui_detailpage_o01_s00). I used 3M command mini hooks to lock it in place with the fan pointed at an angle at the vent slot (wasn't sure if it was going to work, didn't want to drill holes). I ran the usb cord through an already drilled hole that ran to the right side of the seat bench and plugged in the usb fan in the electrical outlet where the Alde was plugged in for shore power source. There was an empty spot in the electrical outlet. I have an O2 fan (http://www.amazon.com/gp/product/B001AVMSEY?psc=1&redirect=true&ref_=oh_aui_detailpage_o08_s00) if I'm not on shore power, but that is a roaming fan and not permanently installed (it roams inside and outside.. I love that little thing!).
It's raining out and I really don't want to go outside to take a picture of the setup /lazy LOL, but I'll post a picture later this weekend. Keep in mind, I have yet to test all of this out. When I run the Alde, I'll have to lift the seat up and access panel and flick on the usb fan switch to get the warm air pushed out from under the "heated" bed. It may or may not be helpful during the cold season, but it was an easily implemented (and cheap) idea. If it doesn't work, I'm not out much $$ and no holes were drilled or wires spliced.
(I know, I know!... a picture!! LOL... I promise I will later after I RTFM how to put the right sized pictures up here).
Cheers!
