In one month we are getting a new T@B 320 CS-S in one month (trading down from a T@B 400 - a story unto itself).
The new T@B 320 CS-S comes with a low pressure propane port that is available at the back of the trailer beneath the Microwave and Fridge.  It has a quick attach connection with an on/off valve at the port.
These have been available on Popup campers for quite some time, but I have no experience with one.  I'm not sure what the "low pressure part" means.   I assume that this kind of thing would be used for a grill, gas lantern,  or additional stove.  Does anyone have experiences?  Hose types?
Thanks for sharing what you can.
nbrandt
(Title edited for search purposes.  Moderator)
2021 T@B Boondock CS-S
2018 Nissan Pathfinder
Ontario, Canada
The hose connections are different because you don’t want to use the regulator on the appliance (grill) as the provided gas pressure is already down regulated.
2020 F150 3.5 ecoboost
Columbus, OH
Ontario, Canada
I did the same thing...You need to unscrew the existing regulator from the grill itself, and then attach the quick connect adapter.
From there, you just snap the gas hose on to the back of the T@B and onto the grill.
I have two hoses now, as I bought a 12' hose initially, then later found they made them in 24' lengths as well.
With the 24' length hose, I no longer feel like I'm restricted in where I can setup the grill.
https://www.amazon.com/gp/product/B07W4YY2LS/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
http://www.rvforum.net/SMF_forum/index.php?topic=82800.0;all#lastPost
https://blog.gopetfriendly.com/hooking-propane-fire-pit-rv-quick-connect/
Ontario, Canada
https://smile.amazon.com/gp/product/B07W4YY2LS/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
https://smile.amazon.com/gp/product/B07TZKKJQG/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Ontario, Canada
This is the exact model I have:
https://www.homedepot.com/p/Weber-Q-1200-1-Burner-Portable-Tabletop-Propane-Gas-Grill-in-Blue-with-Built-In-Thermometer-51080001/205597110
