We've owned several RVs over the years and I've put auxiliary fans in all of them to hopefully improve the performance of the adsorption refrigerators. So when we bought our 2019 T@B 320 BE a few weeks ago I ordered this fan from Amazon (Noctua NFS12APWM). I had installed several on the Airstream Bambi we owned previously. They are known for being quiet and durable. I mounted it on the left side of the top grill opening for the refrigerator. Mounting is a bit of a challenge since the sidewall is mainly foam. So I attached it to the wood framing that runs down the side of the opening and then also attached it to the plastic grill frame. I ran the wires down through the drain opening and then to the battery. The line is equipped with a push-button switch near the battery and a 2 amp fuse. There are probably better ways to mount the fan, but this is what I ended up with. By using the drain opening I didn't have to remove the cooktop to get to the refrigerator wiring to connect to 12V.
But does it improve the performance of the Norcold N180.3D refrigerator? We store our 320 in a garage so it is away from the wind. This makes it easy to measure temperatures in a relatively controlled environment. We have a wireless thermometer with two sensors. I used one on the inside of the frig and one outside. I set the refrigerator to run on 110V and at the maximum setting. Then I recorded the refrigerator temp and ambient temp over 7 hour periods. See the graph. Ambient temps were very similar for the two runs (80-84F). With the fan running the refrigerator cooled faster and got colder. Not a huge difference but significant.
I also measured the max temperature of the top ventilation grill for the refrigerator. Without the fan it ran about 148 F (IR thermometer) and with the fan running about 112 F. I would not be surprised if that plastic grill cover will discolor over time after being exposed to 148 F for hours on end. Another reason to install a fan.
Snohomish WA, 2024 3.6L Grand Cherokee
managed by VE Smart Network
Outstanding retrofit! Sigh. I really, really hate that nuCamp left something this critical up to owners to deal with. Some of us have neither the skills, the tools, nor the physical strength to pull the fridge. This should have been handled before it ever left the factory; the fridge overheat problem is evident to anyone who’s ever run one in summer.alanerickson said:Went a little over the top and added two fans to the exhaust. 3D printed the brackets and that worked perfectly. Held in with 5 pocket screws each and so I don't think it's going anywhere even when bouncing down the road. Fans are 80mm Noctua brand, 12V, and these are the ULN (ultra low noise) model. The brackets are thicker than they look and you can get an idea of that from the one pick where it shows up close and screwed to the bracket.
Tested it out and very little temperature rise in the air coming up but not blowing like crazy either.
Used Wago brand lever connectors for my electrical which short of soldering should be good as anything.
If anyone wants the model of the bracket you can download them at thingiverse at the link below.
Also added an illuminated fan switch since the original setup didn't have anything.
https://www.thingiverse.com/thing:4597251
From the little bit I tested it ........ yes. Turned the fridge on in my garage when the ambient temperature was around 80F. Within an hour I was a couple of degrees above 40 F in the fridge. Came back in another hour and it was around 30F. Normally it would take 2-4 hours to get to 40F alone. But no detailed testing with graphs and stuff like that. But so far I'm pretty impressed at how much better it's cooling and the exhaust air temperature is much lower and it must be at least 30F cooler right by the coil.webers3 said:@alanerickson Did you notice any measurable difference in the fridge performance since adding the fans?
My opinion on Norcold cannot be posted on a family friendly forum, so no, it’s not entirely nüCamp’s fault. I remember when Norcold was the preferred choice over Dometic way back when. Things change, alas!Verna said:@VictoriaP, nüCamp has no idea in 2014 that the 2015 T@B’s with Norcold’s new 3-way fridge model needed an extra fan. It was installed per Norcold’s specs.2014 was a mild summer, but 2015 was hot! There was chocolate, butter, even bread wrappers melting to the counter tops. Marvin and Ed (formerly in the repair shop) figured out the Norcold fan at the left side did not draw the hot air out. They put the muffin fan (computer fan) into the outside vent and that solved the air flow problem.It’s not always nüCamp’s fault when the best plans go awry. The manufacturers some times are at fault for not having proper testing.
Just a little update on this. I was the one who added the dual fans above. We went camping a couple of weeks ago (when it was still reasonably warm) and as a side benefit the temperature control actually seemed much better. Normally with the fridge it seems like you're always having to adjust between too cold and warm. With the fans it seemed to stay much more constant, right around 34F. I think maybe the reason for that is because before the fans were there you had to "turn up the heat" in order to get a decent draft and start cooling, but then once then when the draft started it would overshoot. This separates those two, so you can put a little heat in and it is removed and you don't have to worry about draft. Or at least that's the theory. Anyway, it definitely is better.webers3 said:@alanerickson Did you notice any measurable difference in the fridge performance since adding the fans?
