The right running red light on my 2017 Tab Outback is only partially lit. I was wondering if someone can tell me how to remove the light. I see there is a little notch on the bottom right of the light but I did not want to pry too hard and break it. Also does anyone know where to purchase a new one. Thanks much.
2017 Outback, TV is now a 2018 Ram Eco Diesel
0 ·
https://tab-rv.vanillacommunity.com/discussion/5840/running-lights-not-working
https://tab-rv.vanillacommunity.com/discussion/comment/111916#Comment_111916
You may want to E-mail nüCamp technical support (tech@nuCamprv.com) for advice on removal/replacement. A T@B dealer should be able to get you a replacement light, but you may need to obtain the part number from nüCamp. If not through a dealer, you should be able to find something close, if not an identical replacement, through an RV supply outlet.
Good luck! Please let us know how you resolve the issue.
https://tab-rv.vanillacommunity.com/discussion/11043/marker-light-replacement
If I ever get to changing mine I'll post details.
